My first self made 3D printer presentation and ask for help May 12, 2023 06:54PM |
Re: My first self made 3D printer presentation and ask for help May 13, 2023 12:34AM |
Admin Registered: 13 years ago Posts: 7,000 |
// Homing speeds (linear=mm/min, rotational=°/min) #define HOMING_FEEDRATE_MM_M { (40*60), (40*60), (6*60) }The math is just converting form mm/minute to mm/seconds so X is 40 mm/s homing speed.
Re: My first self made 3D printer presentation and ask for help May 16, 2023 02:57AM |
Re: My first self made 3D printer presentation and ask for help June 04, 2023 06:05PM |
slic3r \ --filament-diameter 1.75 \ --temperature 220 \ --first-layer-bed-temperature 60 \ --bed-temperature 0 \ --nozzle-diameter 0.4 \ --layer-height 0.2 \ --extrusion-width 0.5 \ --infill-speed 40 \ --perimeter-speed 30 \ --bridge-speed 30 \ xyzCalibration_cube.stl
#define HOMING_FEEDRATE { (40*60), (40*60), (6*60) } // set the homing speeds (mm/min) changed z homing from 4*60 to 3*60 // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 2000, 455} //{80,80,4000,455} // default steps per unit for Baja #define DEFAULT_MAX_FEEDRATE {250, 250, 3.3, 25}//{250, 250, 3.3, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000,3000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. // #define DEFAULT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves default was 3000 #define DEFAULT_RETRACT_ACCELERATION 1000 // X, Y, Z and E max acceleration in mm/s^2 for retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
