help with hybrid build
Posted by melvinbrucepaton
April 26, 2016 05:46AM
Hello All
i am busy building a hybrid cnc/ 3d printer , like this one [www.instructables.com].
i am having some problems with the axis controls through repetier, if i move the y axis forward then it moves, when i select y axis back it moves the z axis?
i am using a arduino mega 2560 r3 with a ramps 1.4 to control DQ542ma to run nema 23 motors,
i have disabled all end stops.
any help
thanks
Melvin
Re: help with hybrid build
April 27, 2016 01:12AM
Problem resolved, turns out i needed to add the enable wire from the ramps 1.4 to the DQ542ma"s aswell as enable the the enable xyz in config h.
