[CAN] Metallic Silver Prusa 1 parts
Posted by Sublime
February 16, 2012 02:10AM
One set of Prusa Mendel parts available now. Intrinsically Sublime Web Shop
All parts printed @ 0.25mm layers with 0.35mm nozzle in 4043D PLA
All profits go towards further development of Tantillus
Prusa gen 1 with upgraded parts:
~ gen 2 Z-motor mounts
~ gen 2 Y-motor mount
~ Gregs hinged extruder for 16mm groove mount
~ Triffid Hunters Herringbine gears for Gregs extruder
+ other improved parts (see Github repo for the full list [github.com])
Edited 2 time(s). Last edit at 03/07/2012 07:07PM by Sublime.
Re: [CAN] Prusa Mendel parts
February 28, 2012 02:11AM
Hello Sublime,
I am interested in getting the necessary parts to make my own 3d printer. I live in Calgary. Let me know if you can help me. Thanks.
February 28, 2012 02:16AM
Re: [CAN] Metallic Silver Prusa 1 parts
March 07, 2012 07:08PM
Hi Sublime,
If I'm buying this kit :
http://www.a2aprinter.com/index.php?route=product/product&product_id=42
What set of part should I buy from your site? Prusa 1 or Prusa 2?
Also, while you answer this, can you tell me if this kit is any good before I order it.
Thanks
March 30, 2012 02:05PM
That kit is for the Prusa 1.
But I would not recommend that exact kit as it comes with a Wades extruder (gregs extruder included in my kit) and the hotend that kit comes with is not worth your time or money to purchase.
I would go with a kit like [www.mixshop.com]
Plus:
5 motors
Complete RAMPS kit (arduino, Ramps board, connectors)
4 pololu drivers (or stepstick)
Endstops
Then buy a J-head from Hotends.com
I hope I have not missed anything.
Thanks for the quick answer.
So this
http://www.mixshop.com/store/index.php?main_page=product_info&cPath=18&products_id=59
and
http://shop.3dprinting-r2c2.com/index.php/r2c2-starter-kit-plus.html
then
https://www.hotends.com/index.php?route=product/product&product_id=70
and finally your prusa 1 kit would be a good starter printer? I think it would all go for under 700$CAD too, that's good.
Thanks again for your help, and by the way, your parts looks really good, looking forward to be able to print my own stuff too.
March 30, 2012 06:08PM
Those all look good to me. Just as a note I don't know of anyone using r2c2 right now so you may want to have a look through the forum for reviews and the such. It should be good but as i said I don't know of anyone using it.
May 23, 2012 08:45PM
Hi.
I stumbled across this while researching resource based economies (RBE). I am putting together the numbers and listing out, all those things people have questions about.
This is awesome technology and a perfect fit with RBE :-)
Some of the links above don't work, so I'm having a bit of trouble following. Since you produce the higher quality plastic connectors, I should seek out the metal hardware kit and the print head assemblies seperately?
I live in Ontario. Are there Canadian suppliers I should contact?
I'd also like to know more about the Tantillus. The descriptions I found where sparses. In any case, I get the impression it should be in every workshop around the world. Imagine that, parts on demand with 0 pollution and open source.
Cheers
May 24, 2012 01:53AM
