Selling PLA/ABS plastic 3D filament
Posted by biobp
March 04, 2012 09:00PM
We supply plastic filaments
We are Chinese plastic articles manufacturer, specializing in supply of small plastic articles, in particular, introduction of suitable Reprap, 3D printer, plastic filaments,
we have the following specifications:
1) 3mm and 1.75mm, various colors (existing single color, red, green, yellow, blue, black, white, transparent), matching colors upon request (requires purchase of new colors is greater than the quantity of 100kg), materials includ PLA , ABS, PE, PP, PVC.
2) manufacturers supplying more than 100kg 3mm :
(I) PLA, environmentally friendly biological materials, compostable degradation, a variety of transparent and opaque, grilled corn flavor when processed, the processing temperature of 190 ℃.
(Ii) ABS, engineering plastics, strength, impact resistance, opaque, resistant high temperature above 100 ℃, widely used in electronic products, the processing temperature of 230 ℃, the taste is not very good.
(Iii) PP, PE, commonly used in ordinary plastic, good toughness, PP is harder than PE, PP is resistant to more than 100 ℃, opaque, the processing temperature of 200 ℃.
(Iv) PVC, commonly used in windows and doors, car seals, good toughness, high impact, can be fire-retardant, transparent or opaque, the taste is not good, the processing temperature of 180 ℃.
3) 1.75mm is 15% more expensive than 3mm.
4) Various colors are the same price.
5) More than 100kg can go by shipping, the box size 31 * 41 * 51mm, each box can hold four spool, each spool is 5kg, paper spool. Shipping costs are based on weight and size. We are the manufacturers supplier, we don’ have advantage compared to your local retailer on a small quantity,on large quantity (>100kg) we can be considered as your choice.
Parameter Unit PLA ABS
Trademark   4032D Chimei747
Density g/cm3, 21.5 deg 1.25 1.01
Melt Flow Index 10min,2.16kg 5 5
Melt Point deg 150 230
Heat-Deflection-Temperature deg,0.455MPa 50 85
Yield Strength Mpa, 5mm/min 45 45
Impact Strengh KJ/m 2 5 16
Tensile break % 20% 30
Accuracy - 2.90±0.1mm,1.70±0.1mm 2.90±0.1mm,1.70±0.1mm
Cindy
Shenzhen Bio Plastic Technology Co.,Ltd
Email: sales1@bio-bp.com
Mob: 86-18676398487
open | download - PLA 3D Filament.jpg (48.2 KB)
