reprap.org]
Bill of Materials
Printed parts
This set of parts weighed in at 271g (without power supply brackets).
1x plate_1x.stl which includes the following parts:
1x End effector
1x Extruder
1x Retractable Z probe
2x Power supply bracket (optional)
3x plate_3x.stl which includes the following parts:
3x Bottom vertex
3x Top vertex
3x Vertical carriage
6x Endstop holder
3x Print surface holder
Recommended print settings:
Layer height = 0.2 to 0.3 mm (Done at .3mm Layer Height)
Perimeters = 3 (2)
Top/bottom solid layers = 3 (2)
Infill density = 50%
Note, a PLA End effector may bend or warp if it is not cooled with a fan or insulated. The insulation can be as simple as a loose layer of tin foil to create air pockets between the tin foil and the part. An ABS end effector is less likely to bend. It can also help to insulate parts of the hot end with kapton tape.
I print all of the pieces on a Makerbot Replicator 2.
Quick shipping from USA!
http://www.ebay.com/itm/161234212750?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
