[EU/GER] RepRap Prusa i3 Rework Plastic Part kit from ABS with all screws,Hobbed Bolt,Bearing
Posted by pelo13
Link: Atomic Green
Link: Strong Black
Prusa i3 (Rework) plastic part kit from 100% ABS.
Printed with 0.4mm nozzle, 0.30 Layer high, 50% infill and with 3 solid layer high.
All the parts printed direct to glass for the best optic result.
The ABS filament is made in Holland and is the best in the market right now.
I have replace the stock extruder gear with the famous Herringbone gear for better grip!
Kit including:
Plastic Part kit from ABS (Atomic Green or Strong Black)
1x Hobbed Bolt
4x 608zz Bearing
1x 624zz Bearing
2x Springs
11x M3 12mm Allen screws
17x M3 16mm Allen screws
3x M3 30mm Allen screws
2x M3 45mm Allen screws
9x M4 20mm Allen screws
1x M8 22mm Allen screws
1x M8x20mm grub screw
14x M3 insert lock nuts
5x M4 nuts
2x M5 nuts
1x M8 insert lock nut
1x M8 nut
42x M3 washers
3x M8 washers
cable ties
Edited 1 time(s). Last edit at 03/31/2014 03:44AM by pelo13.
New batch!
Link: Strong Black
