[SLO/EU] Richrap's 3DR plastic parts
Posted by DinoK
November 11, 2014 01:01AM
Richrap's 3DR delta-style RepRap 3D printer. A kit of plastic parts printed in white PLA.
All parts supplied are sourced from up to date STLs with 3 additional upgrades:
3DR RAMPS adapter / converter
[www.youmagine.com]
Three small adapters that allows a standard RAMPS+Mega Electronics kit to fit onto a RichRap 3DR printer
Case for the Full Graphic Smart LCD Controller
[www.thingiverse.com]
This is a case for the Full Graphic Smart LCD Controller. [www.reprapdiscount.com]
3DR GLCD Case Adapter
[www.youmagine.com]
Enables the Full Graphic Smart LCD case to be attached to the RichRap 3DR printer in the same way as the original RichRap XL LCD case.
They are sturdy and dimensionally accurate, holes are predrilled.
The big parts are printed with 30% infill, two perimeters, with a 0.4mm nozzle and 0.18mm layers.
Smaller parts are printed with 35% infill, two perimeters, with a 0.4mm nozzle and 0.09mm layers.
3x Top Electronics Mount V2
3x Bottom Motor Mount V2
3x Top cover cap V2
1x Bottom Boss V2
1x Top Boss V2
1x PLA Spool Holder V2
3x Carriage V2 (for LM6UU)
1x Micro platform V2
12 Joint and Rod adapter V2
3x Print Bed catch V2
3x Spool V2
1x Extruder body V2
1x Greg-style Guidler
1x Herringbone Gear Large
1x Herringbone Gear Small
1x J-head groove mount V2 (for pushfit connectors)
1x LCD Top V2
1x LCD Base V2
1x LCD Controller knob V2
1x LCD Kill Button V2
1x LCD Adapter V2
1x 80mm Fan cover
1x 80mm Fan mount Part A
1x 80mm Fan mount Part B
3x 3DR RAMPS Adapters
1x Bottom_Case_FGD-_pockets
1x Top_Case_FGD
1x Kill_Button_XXL
1x controller_knob_2
4x Spacer_FGD
1x 3DR GLCD Case Adapter
1x 3DR GLCD Case Adapter Spacer
Parts available on Ebay : http://www.ebay.co.uk/itm/281489338401
More info about non-printed parts and assembly is available on:
https://github.com/RichRap/3DR-Delta-Printer
http://richrap.blogspot.com/2013/07/3dr-reprap-delta-printer-part-1-release.html
http://richrap.blogspot.co.uk/2013/08/3dr-reprap-delta-printer-part-2.html
http://richrap.blogspot.co.uk/2013/10/3dr-reprap-delta-assembly-build-part-3.html
http://forums.reprap.org/read.php?178,230812,page=1
All about delta 3d printers in one place [www.deltarap.org]
Re: [SLO/EU] Richrap's 3DR plastic parts
March 11, 2015 11:32AM
I have created a new listing for the item, auction style this time :
http://www.ebay.co.uk/itm/RepRap-Delta-3D-printer-3DR-printed-parts-/281626308687?
