We are the manufacturer of 3d printer, we have a lot of prusa i3 3d printer with high quality
Posted by Anonymous User
Products Description:
Model: he3d - i3
Selling forms: KIT (Assemble it by yourselves!)
1,Frame:Lead screw( Stainless steel material)
Structure:Acrylic sheet(Black or transparent)
2,Print Size:200*200*180mm(Max),
3,Layer thickness:0.1-0.4mm
4,SD Card off-line printingconfused smileyupport
LCD screen:There are 12864
5,XY axis positioning accuracy:0.0125mm,
6,Z axis positioning accuracy:0.004mm
7,Nozlle diameter:0.4mm(standard configuration) (You can choose 0.5)
8,Nozlle temperature:260oC (Max),
9,Platform temperature:120oC (adjustable)(MK3 )3 mm aluminum alloy heat the bed)
10,Platform material:aluminium plate
Printing material:ABS,PLA
11,Material diameter:1.75mm
12,File formatconfused smileyTL,G-code,
13,Machine dimension:420(L)*455(W)* 380mm(H)
14,Package dimension:,460*500*300mm,
15,Power supplygrinning smileyC 24V 400W Voltage input: vc110v - 220 - v
16,OSangry smileyP,WIN7,MAC(
17,Host computer software:Repetier-Host
Software language:English
18,Control panel:RAMPS 1.4
19,weighT:8.5KG
20,CD assembly manual and video tutorials
21,100 grams of printed materials PLA
Product note:
1.this is custom product.
2.Need customers welding and assembly
3.If return the products,we can not sale it again.
Could you send me a $$ - quote and timeline for delivery to Stony Brook, NY.
What kind of welding is required?
Thanks.
I just found them here:
[www.3dprintersonlinestore.com]
