Hello everyone
Our products are in store promotions, if you buy the product and now, We will give you some print filaments and special high temperature adhesive tape for free. If you need, please contact me.
Print size:180x230x140mm
250x230x140mm
sales@reprapmall.com
website:
www.reprapmall.com
Characteristics of Triple Extruder 3D Printer:
Allows to take print in three different material, for example PLA, ABS, PVA (realize special support material to print, PVA).
Three different colors material.
Use different diameter of nozzles to identify the varying thickness of printing layers. Quick print nozzle can fill the inners and fine print nozzle for outer print for smooth finishing.
5 mm thickness aluminum alloy surface temperature, durable heat up faster.
It is a triple extruder machine. You can use it as single as well as double extruder machine.
Minimal sound while printing.
Support component printing, to reduce the edge warping phenomenon the kit parcel.
