[ Project ] 30$ reprap plastic parts kit December 28, 2010 01:09PM |
Re: [ Project ] 30$ reprap plastic parts kit December 30, 2010 12:42PM |
Re: [ Project ] 30$ reprap plastic parts kit December 30, 2010 01:19PM |
Thanks.
Re: [ Project ] 30$ reprap plastic parts kit January 01, 2011 11:17PM |
Re: [ Project ] 30$ reprap plastic parts kit January 02, 2011 12:35AM |
Admin Registered: 19 years ago Posts: 1,791 |
Re: [ Project ] 30$ reprap plastic parts kit January 19, 2011 10:29PM |
Re: [ Project ] 30$ reprap plastic parts kit January 24, 2011 06:34AM |
Re: [ Project ] 30$ reprap plastic parts kit January 28, 2011 11:07PM |
Re: [ Project ] 30$ reprap plastic parts kit January 29, 2011 03:38AM |
Re: [ Project ] 30$ reprap plastic parts kit January 30, 2011 04:13PM |
Re: [ Project ] 30$ reprap plastic parts kit February 04, 2011 12:03AM |
Molds are built through two main methods: standard machining and EDM. Standard Machining, in its conventional form, has historically been the method of building injection molds. With technological development, CNC machining became the predominant means of making more complex molds with more accurate mold details in less time than traditional methods.
The electrical discharge machining (EDM) or spark erosion process has become widely used in mold making. As well as allowing the formation of shapes that are difficult to machine, the process allows pre-hardened molds to be shaped so that no heat treatment is required. Changes to a hardened mold by conventional drilling and milling normally require annealing to soften the mold, followed by heat treatment to harden it again. EDM is a simple process in which a shaped electrode, usually made of copper or graphite, is very slowly lowered onto the mold surface (over a period of many hours), which is immersed in paraffin oil. A voltage applied between tool and mold causes spark erosion of the mold surface in the inverse shape of the electrode.[29]
The cost of manufacturing molds depends on a very large set of factors ranging from number of cavities, size of the parts (and therefore the mold), complexity of the pieces, expected tool longevity, surface finishes and many others. The initial cost is great, however the piece part cost is low, so with greater quantities the overall price decreases.
Re: [ Project ] 30$ reprap plastic parts kit February 05, 2011 06:20AM |
Re: [ Project ] 30$ reprap plastic parts kit February 05, 2011 06:39AM |
Re: [ Project ] 30$ reprap plastic parts kit February 15, 2011 06:45AM |
Re: [ Project ] 30$ reprap plastic parts kit February 19, 2011 08:12PM |
Re: [ Project ] 30$ reprap plastic parts kit March 11, 2011 07:03PM |
Re: [ Project ] 30$ reprap plastic parts kit March 13, 2011 12:39AM |
Re: [ Project ] 30$ reprap plastic parts kit March 13, 2011 06:29AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: [ Project ] 30$ reprap plastic parts kit March 13, 2011 08:49PM |
Re: [ Project ] 30$ reprap plastic parts kit March 14, 2011 04:36PM |
Re: [ Project ] 30$ reprap plastic parts kit March 14, 2011 09:53PM |
Folk are doing up the Sanguinololu
Re: [ Project ] 30$ reprap plastic parts kit March 14, 2011 10:27PM |
Re: [ Project ] 30$ reprap plastic parts kit March 18, 2011 11:27PM |
Re: [ Project ] 30$ reprap plastic parts kit March 19, 2011 12:37AM |
Re: [ Project ] 30$ reprap plastic parts kit March 19, 2011 07:21AM |
printed parts are cast parts' competition. Most people would choose printed parts over cast parts. I think you know why.
Re: [ Project ] 30$ reprap plastic parts kit March 19, 2011 11:01AM |
Re: [ Project ] 30$ reprap plastic parts kit March 19, 2011 12:16PM |
Re: [ Project ] 30$ reprap plastic parts kit March 20, 2011 06:10AM |
As a community we where paying $700 for junk RP parts for Mendel a 16 months ago, even though you could have had them professionally printed for $1200. And your saying that the same group is going to spend $140 on printed parts when they can get functional cast parts for $30-$50?
cons:
requires a higher skill level to make the parts work since the through holes are not created during casting. The user needs to drill holes and do a lot of sanding.
Re: [ Project ] 30$ reprap plastic parts kit March 20, 2011 10:27AM |
Re: [ Project ] 30$ reprap plastic parts kit March 21, 2011 11:29AM |
