Electronics and Al Extruded Repstrap
Posted by nefermu
January 16, 2012 05:33AM
Is it possible to use extruded Al structure with prusa electronics, software, firmware, etc ?
Edited 1 time(s). Last edit at 01/16/2012 06:02AM by nefermu.
Re: Electronics
January 16, 2012 05:34AM
I also want to build a aluminum repstrap. Where can I start Please Help
Re: Electronics and Al Extruded Repstrap
January 16, 2012 11:50AM
Certainly, I don't think it matters. the electronics should work fine with any of the existing common designs. A major departure, like a pick-and-place type machine or a polar robot, would require different firmware, at least. which is probably why there's not more experimentation with those types of machines.
January 18, 2012 03:12PM
MendelMax is a Prusa, redesigned with aluminum extrusion. Electronics, software, firmware, and the x-axis all can be moved from an existing mendel (Sells or Prusa) without modification.
