reprapdiscount ordbot hadron, build and kit review March 25, 2013 07:12AM |
Re: reprapdiscount ordbot hadron, build and kit review March 26, 2013 05:39AM |
Re: reprapdiscount ordbot hadron, build and kit review March 28, 2013 08:03AM |
Re: reprapdiscount ordbot hadron, build and kit review July 03, 2013 03:59PM |
Re: reprapdiscount ordbot hadron, build and kit review October 27, 2013 12:39PM |
Re: reprapdiscount ordbot hadron, build and kit review October 28, 2013 05:31PM |
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 09:34AM |
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 02:39PM |
Jean-Luc
I'm new in the forum just bought an Ordbor hadron in DIY kit 2 month ago from reprapdiscount, very fast delivery and good support (fast answear to my emailssss).
To BOBC, the number of extruder sepend of the electronic and software i don't think that you can easely put 3 head and most of the soft are able to manage on or two extruder.
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 04:27PM |
bobc
I noticed some kits from Reprapdiscount on ebay, I have always liked the look of the Ord bots.
I'd like to know if the Hadron can fit a dual or triple extruder? Or maybe the X can be extended to allow for this without losing build area?
I have 1m of makerslide rail spare, maybe I can use that here.
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 04:30PM |
cozmicray
Rumba
Where can I see more info on extruders
is there a website / store?
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 04:42PM |
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 05:01PM |
dave3d
I have just built an Ord Bot Hadron which I got from ATI. Had it shipped from the US to the UK. I am a newbie (or was) and I spent about 50 hours putting it together. This included the mechanical build and wiring the electronics. There was no pre assembly at all, just a box of bits without any instructions. I damaged the Arduino and Ramps boards by wrongly connecting the end stops. I had to replace them.
On the plus side it is built using Makerslide and this makes it a really nice compact and robust design. Better than steel rods and plastic corners.
The extruder was not included and I made the mistake of buying a QU-BD MBE extruder. I wasted many many hours trying to get it working and finally gave up. I have now got a bog standard Gregs Wade extruder with a hotends.com jhead. I haven't looked back since.
Still a few problems but getting there slowly.
Twin extruders are possible but it would be better with a bowden setup imho. Two motors flying about at high speed would be too much weight I think. This is a project I plan in the future. One advantage is the Ord Bot can print fast.
Maybe I should have ordered mine from Reprapdiscount. Looks a nice job.
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 05:16PM |
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 05:18PM |
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 05:40PM |
dave3d
I hope to have hardware support for 9 extruders.|
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 05:42PM |
dave3d
Hi Elvira,
I think are you talking about two direct drive extruders which are a bit lighter. Two Wade extruders would be heavier.
Running at 200% feed rate with two Wade/ Nema 17 motors would shake the Ord Bot about I think.
The problem with a Bowden setup is where to mount the extruders? Maybe move the electonics to a separate box to make space.
, i am just too busy|
Re: reprapdiscount ordbot hadron, build and kit review November 07, 2013 06:18PM |
Re: reprapdiscount ordbot hadron, build and kit review November 08, 2013 07:09PM |
bobc
Hi Jean-Luc
The electronics and software is not a problem for me, I have a triple extruder electronics. The problem is I am not so good on the mechanical side, and there is currently only one RepRap with a triple extruder.
Re: reprapdiscount ordbot hadron, build and kit review November 09, 2013 07:20AM |
Jean-Luc
First, are you using a OrdBot hadron ? If yes i think That it´s not à big problem to have 2 extruders face to face.
For 3 extruders i would place them in star or triangle with an extention plate.
If you are worried about the extruder mouve, you can put the extruder on the back of the printer (like ultimaker extruder system or Bowden extruder) in this case i think that you could be able to have 4 extruders, 4 heads together in the mouving plate (X) and the extruders in the back.
Jean-Luc
But i will have an other question, why will you need to use more than 2 extruders? Or what for?
Re: reprapdiscount ordbot hadron, build and kit review November 12, 2013 08:48AM |
bobc
Multiple colours, materials.
Re: reprapdiscount ordbot hadron, build and kit review November 21, 2013 06:41PM |
bobc
I *think* a piece of t-slot would bolt across the top of the ordbot, which could be used to mount extruders.
I find t-slot much nicer than threaded rod, it may be not be so universal as threaded rod, but is much more solid, and dare I say "professional quality". There's a supplier in the UK which provide a great service who also cut to size.
Re: reprapdiscount ordbot hadron, build and kit review November 23, 2013 07:20AM |
