Acetal slide bearings in extrusion to replace smooth rods March 04, 2014 04:01PM |
). I posted pictures and some info in the Ormerod section [forums.reprap.org], but I guess here is a better place to post. The bearings I used are these [www.aluminium-profile.co.uk] cut into three, costing around 45p per piece. |
Re: Acetal slide bearings in extrusion to replace smooth rods March 04, 2014 04:11PM |
Re: Acetal slide bearings in extrusion to replace smooth rods March 04, 2014 05:58PM |
Re: Acetal slide bearings in extrusion to replace smooth rods March 04, 2014 11:00PM |
Re: Acetal slide bearings in extrusion to replace smooth rods March 05, 2014 01:12PM |
Admin Registered: 17 years ago Posts: 1,472 |
gmh39
Yea, I dont think I have seen a printer use rack and pinion yet. So you'll be on the bleeding edge. It is definitely nice since it is something you can print, but I think buying is much better because you will probably get better accuracy and sizing.
Re: Acetal slide bearings in extrusion to replace smooth rods March 05, 2014 01:35PM |
