diy ultimaker of extruded aluminium December 06, 2014 10:26AM |
Re: diy ultimaker of extruded aluminium December 06, 2014 08:41PM |
Re: diy ultimaker of extruded aluminium December 15, 2014 02:53AM |
Re: diy ultimaker of extruded aluminium December 15, 2014 08:09PM |
Re: diy ultimaker of extruded aluminium December 16, 2014 03:37AM |
Re: diy ultimaker of extruded aluminium December 17, 2014 07:19AM |
MPower
For Misumi, you can calculate the deflection using the following tables:
[www.misumiusa.com]
[www.misumiusa.com]
Re: diy ultimaker of extruded aluminium February 03, 2015 04:53PM |
Re: diy ultimaker of extruded aluminium February 04, 2015 08:32AM |
Alexander1984
I would go for 30x30!
it is much sturdier and has way better overall stability.
Also i would not connect the aluminum extrusion by printed parts but rather thos metal 90° angles designed to connect the profiles.
That way you get a frame you can sit on top or stand upon and it will be rock solid -> and Yes I am speeking out of experience - i build an enclosure with 30x30 extrusion and the bigger version of the 90° connectors.
I can easily stand on the housing I built. seems really rigid.
use printed parts to mount accesories to the extrusion - that`ll work.
But for anything else use aluminum - you`ll be happy you went this route lateron^^
Alex
