Mendel design 4 ballscrews
Posted by Mark Bauer
April 30, 2010 08:32PM
Call me a little crazy, but I know that the mendel can reprint its own parts, however has anyone tried to create a machine that uses a Ballscrew for XY and Z? (yes 4 ball screws 1 x 1 y and 2 z).
Ballscrews give greater accuracy and using some low cost aluminium prefab - mix it with a few ballscrews would make a stronger design and more rigid framework.
Personally I've got a lot of old ITEM aluminium kicking around which is engineered aluminium and would make a stronger system.
Mark.
Re: Mendel design 4 ballscrews
April 30, 2010 11:17PM
Unless I completely don't know what a ball screw is, the McWire repstrap uses something similar, except without a ball bearing. The main problem encountered there is that they're too slow, but I'm sure that could change with a different pitch. If I'm not mistaken, the mendel z-axis almost uses ball screws, too.
May 01, 2010 02:43AM
McWire and WolfStrap, etc use generic threaded rod. If you take a cross-section, it has a triangular or saw-tooth shape. This is optimal for fasteners but not optimal for motion control. We use it for motion control anyway because it is cheap and it works, if not well, and not quickly.
[reprap.org]
uses acme threaded rod. This has a square cross section thread, and is optimized for motion control. You may see it in your inkjet printer, the threaded rod of your garage door closing mechanism, etc.
[en.wikipedia.org]
is a different beast. It has a cross-section like a series of cicular bites. Rather than thread riding in a threaded nut, small ball bearings recirculate between the threaded rod and the inside of the "Nut".
[www.youtube.com]
I've moved this thread to the extruded aluminum forum. grinning smiley
Edited 1 time(s). Last edit at 05/01/2010 03:55AM by SebastienBailard.
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
May 01, 2010 01:56PM
Real circulating ball screw assemblies are expensive - VERY expensive. Hundreds of dollars apiece.
I'm currently designing a mendel version with a larger print area (12in x 12in x 10in high), using Acme nuts and screws instead of belts. Much less expensive. Still slow, though, compared to the belt drive x and y axes. My current (experimental) x-axis design requires eight times as many turns of the motor for the same amount of movement. But I'm still working on it...
May 23, 2010 01:25PM
you could get multistart acme screws and it would be much faster moving. a 1/2" 10 turn 5 start would give you two rotations per inch of linear movement
July 02, 2010 06:02PM
> apiece.
Wow, I guess I've been underpaying for my ballnuts and screws! McMaster-Carr has a 5/8" ballnut for $26.29 (part #
5966K16) and the matching 5/8" ballscrew (5966K26) is $10.22 per foot.
[haveblue.org]
July 27, 2010 01:07AM
Eustace, that sounds cool. Where in the wiki are you documenting? smiling bouncing smiley
Have Blue, do you know the brandname for the ballnuts and screws? McMaster-Carr won't ship up here to Canada because us Canuks might tranship stuff to the Axis of Evil. (no kidding) smoking smiley
Also, where in the wiki are you documenting?
November 30, 2010 10:56AM
The ballnuts/ballscrews I get from McMaster-Carr are made by Thomson: [www.thomsonbsa.com]
I had no idea McMaster won't ship to Canuckistan - if anyone up yonder needs McMaster goods, drop me a line and I can get them for you.
As for documenting in the wiki, I have something of an aversion to wikis - I always feel like I'm intruding on someone else's space, I have no idea how to properly edit inclusions, and I have no clue as to where such information would best be located. In short, when I look for answers, I search the forums rather than digging through the wiki, and I'm guessing a fair number of others do so as well.
[haveblue.org]
November 30, 2010 08:40PM
Does your offer extend to Australia? I'd like to get some of this:
[www.mcmaster.com]
November 30, 2010 09:25PM
Sure, I can certainly send stuff over to Australia as well. Drop me an email and let me know your McMaster shopping list.
[haveblue.org]
December 01, 2010 12:34AM
No worries, you're a RepRap developer and the wiki belongs to you, it's your space:
http://reprap.org/wiki/Rather_Blue_T-Slot_Bot smiling bouncing smiley
Forums are great for commentary, feedback, etc. But it's the files and docs in the wiki that keep us going. If you do up a machine strictly as a series of blog posts and forum entries with file attachments, that's well and good, but it's useless to the newbies who wander into the wiki hoping to find actual documentation. I mean, can you imagine Mendel if it were just a series of blog posts and forum entries? smileys with beer
Since you're the lead developer for this sexy new machine ...
December 01, 2010 12:58AM
Hope the name is ok, btw. grinning smiley
December 01, 2010 10:17AM
I hadn't yet figured out a name for the machine, but I'll make sure to post relevant information to the wiki if I actually get to the point of completing the design. I have to finish building the full-size router first, after all...
[haveblue.org]
December 02, 2010 10:43AM
That was for the full-size router, actually.smiling bouncing smiley
(RepRap doesn't have one yet.)
