Re: Connecting extruded aluminium? December 31, 2015 11:19AM |
Re: Connecting extruded aluminium? December 31, 2015 12:02PM |
Re: Connecting extruded aluminium? December 31, 2015 12:41PM |
Anybody who is able to buy and mount a kit should be able to reproduce my printer and it should give a good quality of course. The intention is meant for my use only, but I have some new ideas which I will test and I will provide. What would be making me more proud of my design if anybody copies parts of it or somebody rebuild the whole printer? I designed some parts for my Ormerod 2 intended for my use only but I provided the design on thingiverse. Before I was able to print it and test it by myself I got feedback from one person who used my design successfully. That was a really good feeling especially as it was a problematic design regarding stability.Quote
the_digital_dentist
Treito
I have no welding equipment and the welding was some sort of joke, but this would have been the stablest variant. The second problem is that it should be of course some sort of RepRap printer so easily to recreate.
Ah, philosophy! Philosophy is like a bag of bricks you carry around everywhere you go. Who are you carrying it for? Why not just set it down?
In your philosophy, what is the definition of "easy" and to whom does it apply? Someone with welding equipment can easily recreate a welded frame, a quadriplegic can't. Are you planning to go into production or building a printer for your own use? How does this philosophical ideal rank among the numerous constraints you're putting on this project? Philosophy and quality are in direct opposition to each other- the more 3D printer reproducible the machine is- i.e the more printed content a printer has- the less likely it is to produce quality parts. Maybe your philosophy can be interpreted in a way that will allow you to proceed. Maybe it's OK if the printer can't reproduce itself but can produce high quality parts for other printer designs. Wouldn't it be better, philosophically speaking, to be able to produce very high quality parts so that the printers made from those parts work well, or is the philosophy only about quantity, not quality?
The computer magazine publisher did not see any differences between a closed chamber or open frame. I also can print with my printer nearly warp-free (between 0.0 and 0.1mm). The print surface is also important. Okay I may have some fail prints but I bet that you will have them with a chamber, too. And I nearly found settings which are good to use so that there is no warping. I even managed a hardly to print part warp-free where even PLA was warping. But my Idea was to find a design which can be extended to a chamber somehow, but at the moment I do not see a really need for this.Quote
Treito
2) Is out of race. It would not make me happy looking at it. Besides that a German computer magazine publisher (Heise) tested closed chambers versus open chambers and they did not notice any differences. Unfortunately it was an internal test only so it was mentioned only with one sentence in an article. I would more prefer a design more like snappy even though it is not a CoreXY and I would always use GT2 belts. But it would be more expensive and more loud than Aluminium extrusions.
It doesn't matter what you use to make the frame, if you intend to print with ABS you will need a closed build chamber. The chamber must be a warm 45-50C, or ABS prints will warp and delaminate. That means you should put the electronics outside the build chamber, so unlike most designs where positioning the electronics and cables are an afterthought, you should plan the location in advance and design the frame to include warm and cool zones, and design it for easy access to the electronics for maintenance and repairs.
It was meant as problem during the mounting. If the screws are tight the extrusion will not twist, but especially while putting them tight the extrusion may rotate or I am afraid of this. It seems that you got other experience in this way.Quote
Treito
4) and 5) Disadvantage: You may twist the extrusion
Yes, a single screw butt joint can allow the frame pieces to rotate unless there is something attached to them that prevents rotation. That is how my printer is built. Once the screws are tightened down it is very difficult to rotate any of the frame pieces. In the two years my original printer was in use the screws never loosened and none of the frame pieces ever rotated. The machine has been in its current form for a year without any rotation. There are no rotational forces applied, so the pieces don't rotate. Look at it this way- there's nothing to prevent a screw and nut from rotating either, yet without tools it is very difficult to get them to rotate. The frame piece receiving the screw is a nut.
My bed support of the Ormerod 2 is printed with PLA. There is no problem so far. Okay there is a distance between it and the bed because of the leveling. But as long as you have a good insulation there should not be a big problem. I used another design for my Ormerod 1 for a time and after I dismounted it there were no damages to the plastic.Quote
Treito
1) Maybe for smaller areas like the heated bed carriage. At a Facebook group I nearly got killed as they told me as I considered this idea. It would not be precisely enough as no printer prints 90° perfectly and it would be too weak. Even if I print a dice? You could directly print connectors onto it so it should not be weak, should it?
I would avoid putting any printed parts anywhere near the bed plate. Printed corners are not as strong, rigid, or reliable as metal to metal attachment, and they don't look very nice, but they may be strong, rigid, and reliable enough. People have successfully built printers with them. Printing corner cubes could work, but how is butting aluminum to a piece of plastic better than butting aluminum to aluminum? I milled the ends of the frame pieces square so the butt joints in my frame needed no shims. Whether you're butting aluminum to aluminum or to plastic, you may have to shim the joint to make it square, depending on how square the aluminum is cut and how square the plastic is printed.
That would be of course an option, but not that precise. It may only work as addition.Quote
Treito
Even if the plate only costs 5.34€, why is it still so expensive? 1 meter extrusions needs more material and costs only half of the price. Okay it is of course another production process but in my eyes it is not more worth than 3€. I guess the margin of the extrusion is not much and the money comes back with the help of the additional parts needed like inkjet printers.
Aluminum plate is cheap and so is a drill bit. You can easily make the flat plate connectors with a saw and a hand drill. Then you attach the plates to the frame using carriage bolts. It's a lot of hardware, but it's pretty cheap, and pretty easy. If the screw holes in the plate are slightly oversized, there will be enough slop that you'll easily be able to make the joint square.
Re: Connecting extruded aluminium? December 31, 2015 01:10PM |
the_digital_dentist
Such distortion only matters if you're trying to use the frame as the reference for the alignment of the axes. Many printer designs do just that (including my own, to some extent), but it doesn't have to be that way. The frame can be just a rigid frame in which to mount parts that are made alignable independent of it, and something to enclose the machine.
Re: Connecting extruded aluminium? December 31, 2015 07:10PM |
Treito
Re: Connecting extruded aluminium? December 31, 2015 07:37PM |
Re: Connecting extruded aluminium? January 02, 2016 09:01AM |
TreitoIt was meant as problem during the mounting. If the screws are tight the extrusion will not twist, but especially while putting them tight the extrusion may rotate or I am afraid of this. It seems that you got other experience in this way.Quote
the_digital_dentistQuote
Treito
Re: Connecting extruded aluminium? January 02, 2016 10:24AM |
Re: Connecting extruded aluminium? January 03, 2016 12:27AM |
Re: Connecting extruded aluminium? January 03, 2016 02:48AM |
Re: Connecting extruded aluminium? January 03, 2016 08:01AM |
Re: Connecting extruded aluminium? January 03, 2016 09:07AM |
Re: Connecting extruded aluminium? January 03, 2016 04:33PM |
Re: Connecting extruded aluminium? January 03, 2016 04:37PM |
LarsK
You can get the plates much cheaper then 27€ - here 5.34€
[vslot-europe.com]
LarsK
It is not good against moments of bending alone because it is only secured with one screw. If you combine this with an end-screw then it will be better. But if you wanna start using brackets to reinforce the structure, then I think this is the best choice:
[www.motedis.com]
Re: Connecting extruded aluminium? January 03, 2016 07:52PM |
Re: Connecting extruded aluminium? January 03, 2016 09:01PM |
Re: Connecting extruded aluminium? January 03, 2016 10:16PM |
Re: Connecting extruded aluminium? January 05, 2016 12:59AM |
Re: Connecting extruded aluminium? January 05, 2016 08:33AM |
Re: Connecting extruded aluminium? January 05, 2016 01:18PM |
Re: Connecting extruded aluminium? March 02, 2016 03:41AM |
Re: Connecting extruded aluminium? March 05, 2016 10:13AM |
Re: Connecting extruded aluminium? March 05, 2016 11:06AM |
Re: Connecting extruded aluminium? March 05, 2016 12:03PM |
Re: Connecting extruded aluminium? March 05, 2016 12:31PM |
Re: Connecting extruded aluminium? March 05, 2016 03:44PM |
Re: Connecting extruded aluminium? March 05, 2016 04:43PM |
the_digital_dentist
I don't make money off of it. I print stuff I need with it.
Re: Connecting extruded aluminium? March 06, 2016 02:07AM |
Re: Connecting extruded aluminium? March 06, 2016 10:27AM |
Re: Connecting extruded aluminium? March 06, 2016 10:49AM |
