This is a tank
Posted by cwaa
This is a tank
August 21, 2016 03:28PM
When I decided to build my own printer, one thing I wanted was to avoid the polished rods and sliding bushings most printers are made with. They flex and can pass vibrations to the print head. This design uses two ball bearings on each rubber tired wheel. I can stand on the frame and it can be used for light CNC work.
This frame is available through a company called "Open Builds". My frame is based on several models from Open Builds. The controller, extruder, heated bed and hot end were selections I made after deciding on the frame and linear movement methods. As to how fast it will print, I am still learning. There is quite a lot of inertia in the X and Y axis. But the movements are rock solid. I am using an aluminum printing surface, over an aluminum heating plate. They are insulated from the aluminum build plate and carriage. I use a proximity sensor to level the bed automatically.
I think a lot of Open Builds............Take a look.
[www.openbuilds.com]
This machine has a double carriage and two screws on the Z axis. I explored a single stepper with a belt for the Z axis and found the double motor and screw a very inexpensive alternative to a belt.
Oh, something else about that frame. The carriage plates can be purchased or made, but the purchased plates come pre-drilled to accept the rubber tired wheels, and one side has an eccentric to tighten the wheels into the slot. Very clever design .
Re: This is a tank
August 22, 2016 11:02AM
Ahh nice, the Voxel Ox by Marshall Peck. I've made one of these as well but over the past year it has taken on many modifications!
-- Highly modified X axis and gantry to be lighter, and more space efficient in both X and Z planes. I've knocked at least 400/500 grams off the extruder carriage.
-- New bottom frame to store electronics. Makes the machine look like an absolute beast, yet it's still the same size....
-- Larger machined aluminium bed, 280x280mm with 240v heater. (not pictured)
-- Single motor Z axis. Easily the best upgrade. Actually pretty cheap. I used 2 more openbuilds plates for simplicity, but a printed alternative would work well here making it cheaper than a 2x motor configuration.
-- New titan extruder.
Next up will be a full heated enclosure, and possibly water cooling for the motors
Re: This is a tank
August 24, 2016 11:54AM
When I priced the belt, two extra idler pulleys and two more belt pulleys, it was far cheaper to just buy an additional motor and slave them together. Where did your find you loop belt and how much did it cost?
Edited 1 time(s). Last edit at 08/24/2016 11:55AM by cwaa.
Re: This is a tank
August 24, 2016 01:54PM
Cheapness is why you see so many machines with two motors in the Z axis. The kit seller knows you won't think through the problems of two motors because that shiny, sparkly low price has you mezmerized, and besides, most of the machines out there have dual z motors, so it must be good, right?. The problem is that the motors and screws can easily get out of sync, causing the X axis to tilt relative to the Z axis.
How do they get out of sync? let's see...
1) someone (maybe even a small child) turns one of the screws manually- it's very easy to do without tools when the motors have no current.
2) microstepping drivers power off with motors that are not at full step positions. The motors jump to their respective nearest full step points sometimes in opposite directions.
3) some mechanical misalignment causes one screw to bind and the motor skips.
4) a wiring problem- a motor connector or wire comes loose on one motor or the other
5) a shaft coupler screw loosens due to vibration
6) a driver problem- if using separate drivers for the motors, one or the other may fail
If you want to get the X axis out of the way for doing maintenance on the bed or extruder, you have to either power up the host computer and printer, then open the host software and command the Z axis to jog, or you have to turn on the printer and step through multiple menus to jog the Z axis using the LCD control panel. Leveling and zeroing the bed is also a PITA with dual motors, again because you must drive them from the controller.
A single motor/loop belt system locks the Z axis screws together and they never get out of sync (well, OK, if a grub screw on one pulley comes loose they can). If you want to raise the X axis to work on the extruder or bed, you simply grab the belt and pull it until the X axis is a high as you need. Nothing has to be powered up, you don't have to step through menus, and when you let go of the belt, the screws will still be synced perfectly. You'll never waste time trying to realign the X and Z axes, and maintenance is much faster and easier, as is leveling and zeroing the bed.
Re: This is a tank
August 24, 2016 03:26PM
I can't remember how much the belt cost, but it was in the range of normally priced GT2 belt. I searched aliexpress and ordered a batch of 5, and I remember it being less than £10 at least. Considering the cost of the rest of the machine, it really wasn't a problem. Other parts needed? a 'standard' nema 17 bracket mount (£1-2) and whatever bearings you have lying around, and also some of the openbuilds mounts. You could print these though, they don't need to be particularly strong. The total cost for me to do the whole single motor Z upgrade probably cost around £40, but I could easily have done it for less than £10-15.
Bed levelling was something I had to do very regularly, but now I never have to do it. A single Z motor and an opto endstop are the upgrades that did this, and I attribute most of the success to the single Z motor. You may not see the benefits of a single Z screw as you have auto bed levelling, but the longevity of your machine will notice it. An uneven gantry will put unnecessarily stress on one side of your machine, wearing down bearings, nuts, lead screws, motors etc.
Re: This is a tank
April 19, 2017 05:31PM
I think the problems with the dual Z axis motors are way over stated. I have been running mine and have not had any z axis problems in over a year. I do level the bed once a month or so and I block the z axis when I do it. Still would not trade for the more expensive and vibrating belt.
Re: This is a tank
April 19, 2017 08:55PM
Vibrating belt?
Whether you experience the problems (or even recognize them) doesn't mean they aren't real. You're confusing your personal experience with common experience. A quick perusal of these forums will bring up plenty of posts from people who have had the very real problem of Z axis screws losing sync. A vibrating belt is no more of a problem in the Z axis than it is in X or Y, except that the Z axis moves much less than X or Y. You could say that the "problem" of a vibrating Z belt is so rare that it's imaginary.
The majority of people who have the Z screws losing sync problem think that releveling the bed or autoleveling will fix it. It doesn't. Autoleveling will get the first layer to stick, but if the screws have lost sync the X axis will be tilted and prints will be skewed. That means you won't be able to print accurately shaped parts so things like gears that mesh or screw-together parts won't work as designed/intended.
There are a lot of people out there who never print anything but yoda heads and tug boats and will never recognize the problem until the X axis tilt gets so bad that the Z axis binds and stops moving. That may take a while.
Edited 1 time(s). Last edit at 04/19/2017 08:56PM by the_digital_dentist.
Re: This is a tank
April 24, 2017 10:27AM
I guess I will wait until I see some of the problems you are talking about. I have been at this for more than a year, when do these type problems start to appear?
Re: This is a tank
May 13, 2017 10:38AM
the_digital_dentist
chris (nophead) had an idea which he provided with the mendel90, which helped with this: a couple of "pointy arrows" which you put on the lead screws, along-side some pointy-pointed things that are attached to the base, at which the pointy-arrows can point.
once you have the printbed aligned and all happy... *at z-level 0*... you simply adjust the arrows to point at their pointy-pointed things, and you can *instantly* tell if (a) the z-home didn't actually work (b) one of the z-screws has got out of sync for *any* reason, even during the operation of the printer. i used to watch them, mesmerised, to make sure that they rotated by the exact same amount on each Z-lift, and i got a pretty good visual indication of how much they would turn for a given 0.15, 0.2 or 0.3mm z-lift.
what's nice about this, dd, is that it works even if you had a single z-screw (and belt) like in this design: you could still conceivably have a grub screw come looes on a single-z-motor design, and nophead's arrows idea would help with that just as well as if you had dual separate z-motors.
Re: This is a tank
May 15, 2017 10:58AM
Great idea!
Thanks
