Re: Riki200 August 05, 2017 09:45AM |
Re: Riki200 first print! August 09, 2017 02:12AM |
Re: Riki200 August 09, 2017 02:19AM |
Re: Riki200 August 09, 2017 02:26AM |
Re: Riki200 August 09, 2017 09:33AM |
Re: Riki200 August 09, 2017 09:52AM |
the_digital_dentist
It's always satisfying to get that first print off a new machine. First prints always look like crap because we want to see it print and can't wait until everything is tweaked... Besides, how else would we know what has to be tweaked? I'm sure you'll get it tuned up.
Re: Riki200 August 10, 2017 10:05AM |
although.... in this video it doesn't seem that way, the twin 40mm fans must have some sort of resonance that the microphone picks up|
Re: Riki200 August 11, 2017 07:00AM |
the "legs" merge together into a ring, similar to the mendel90 fan duct. it was supposed to be designed for not needing any support whilst printing, but some of the angles are around 70 degrees, which is just a bit too much. manual support which can be snapped off has done the trick.
Re: Riki200 August 12, 2017 07:02PM |
Re: Riki200 August 13, 2017 02:15AM |
gtj
Looks like we're on the same track (kinda), but you're much further along than I am.
[forums.reprap.org]
i'll be converting over to ultimaker-style as well... *sigh*....
Re: Riki200 August 13, 2017 03:27AM |
Re: Riki200 August 14, 2017 06:30AM |
Re: Riki200 August 15, 2017 03:44AM |
Re: Riki200 August 15, 2017 03:56AM |
o_lampe
WOW
That would be a deep fall from a uniquely ( still overly complex IMHO ) design to a well aged Ultimaker design.
I guess, you won't go the carbon rod route, like gtj?
Are you really sure, there is no other way to save the clamped dual belt-design?
What if you place the two belts on top of each other?
( Actually I got confused how the belts are routed now, after all these sketches )
basically as in benson's sketch except without those "outrigger" bearings for the outer belt. that was... a mistake.|
Re: Riki200 August 15, 2017 09:38AM |
Re: Riki200 August 16, 2017 11:02PM |
Re: Riki200 August 17, 2017 01:50AM |
chrigel
Ok, started to think a bit about Benson's "Ultimaker-style" belt concept... augmented with some info I gathered from the Riki200 page.
Unfortunately I had to make some assumptions as the BOM link doesn't seem to be working (same with the other links to hands.com).
When I read about the intention to use a 40:1 gear from the NEMA17 to the rod that moves the gantry belts,
I was wondering whether the motors can keep up with the speed required to be able to print fast enough - also since stepper motors lose torque at higher speeds (see e.g. page 2 of this NEMA17 datasheet.
So I created a little calculator and pre-filled it with the numbers I could come up with from the information I gathered.
Note that I didn't even put in the 40:1 gear ratio but left it as 2:1 to account for just the pulley arrangement proposed by Benson being driven directly by the motor.
Still, the results are, for the proposed 400mm/s print speed, a rather staggering 1200RPM for the motor, which (in the PDF above) suggests, at best and at the proposed 24V, a torque of only ~44% of the holding torque (which is already lower than the 2:1 gain obtained by the pulley arrangement itself).
Keep in mind that I am by no means an expert and may also have errors in my calculator, so please let me know if you find bugs or other errors in this line of reasoning. I also have to admit that I am a little confused by the torque/speed plots on that PDF as they start out at way lower numbers than the Holding Torque numbers given in the table on page 1.
Re: Riki200 August 17, 2017 03:22AM |
lkcl
chrigel
which isn't the case. the 40:1 wormdrive is in the flex3drive - in the extruder only.
http://reprap.org/wiki/Riki200
Concept 3
The concept here is to use twin belts per axis with 340mm 5mm OD rods connecting the two, in a "standard" industrial layout. However a pulley system is to be introduced which will halve the force per belt section as well as double the accuracy. A 40:1 GT2 gear on the 5mm rod will also be deployed along with a closed loop belt, to give extra accuracy.
lkcl
ok so the actual numbers to use are:
* 400 steps/rev (0.9 deg) steppers
* 1.68A motors ( i think these are 44oz.in ones: i got the highest torque 0.9deg NEMA17s possible) spec OK42STH38-1684MA
* 20T-40T closed loop belt providing 2:1 gearing
* 2:1 pulley ratio
so that's *four* to one gearing total. which at 2400mm/sec exceeds the maximum speed listed on the graphs. hmmm.... that's bad.
lkcl
[snip]it does sound like i need to cut the pulleys. in theory i could do direct-drive (5mm coupling) of the NEMA17s to the planned 400mm long 5mm shaft but that means it sticks out an awful long way, meaning a lot of plastic a heck of a long way away from rigid metal.
pulley-to-gantry-belt
gear/belt+pulley
| motor
| motor
lkcl
ok - thank you chrigel. i'm... relieved someone's paying attention
Re: Riki200 August 17, 2017 03:35AM |
Re: Riki200 August 17, 2017 03:38AM |
chrigel
...or should this read "A 40:20 = 2:1 GT2 gear on the 5mm rod"?
Thanks, I updated the calculator. You probably meant 2400RPM instead of 2400mm/sec there.
Any chance we could get links to the motor datasheet and the 20T-40T gearing you're looking at? A quick search on the web didn't bring up anything useful... or I should probably just wait until you fix that BOM link.
*might* be possible to find it from that P/N. if you do let me know, i'll add it to the python source.Quote
Sorry for the noob question, but what do you mean by "direct-drive (5mm coupling)"? Couldn't the motor driving the rod sit more or less centered between the two belts driven by the rod? Such as:
Glad to be helpful, I find this a very interesting project - partly because I'm one of your future customers
Re: Riki200 August 17, 2017 04:03AM |
chrigel
Instead of removing the pulley system, couldn't you choose a 1:1 gearing (if available)? That way we'd keep the advantage of the belt tension being halved.
Re: Riki200 August 17, 2017 08:50AM |
Re: Riki200 August 18, 2017 02:25AM |
lkcl
[...] the main thing is, i wanted people to be able to do high-accuracy with this design as well, meaning the possibility of running at much slower speeds, using e.g. 0.15mm E3D experimental nozzles, where you actually start to get artefacts from micro-stepping showing up in the print if you have a 1:1 ratio.
...really appreciate your efforts to make it as versatile and capable as possible!Quote
lkcl
i think you're right, chrigel: just dropping in a pair of GT2-6mm-20T gears, one on the motor and one on the pulley, keeping the closed-loop belt, would do the trick.
lkcl
the only thing that concerns me is, there's going to be one hell of a lot of force on the bearings (and the plastic holding them), so i might have to follow the_digital_dentist's advice and use a solid block to hold the bearings that the 400mm long 5mm rod goes through.
Re: Riki200 August 18, 2017 03:01AM |
chrigel
Wow, that's fantastic. You know, I am more and more looking forward to owning this printer myself...really appreciate your efforts to make it as versatile and capable as possible!
Yes, that's what I was trying to illustrate with my crappy ASCII graphic above... sorry, should've been more clear. Judging from your last screenshot, I see you're also still planning to implement the 2:1 pulley system proposed by Benson for the gantry belts. Great you can use the vertical printbed's z-uprights for fixing the motors at adjustable distances.
Here are some of my thoughts on this topic:
The top shows your current belt layout (at least as I understand it), the bottom shows an alternative. Left are the front, right the side views of the layouts.
So... if we could shift the belt planes out of the frame so they don't intersect the gantry rails, I think this could have the following mechanical advantages:
Now for the disadvantages:
3. Increased printer volume due to extending rods past the frame and the gantry belts running outside the frame rather than on top.
4. The gantry belts now have to have their fixed end points outside the frame as well (see point C).
I think your genius way of interlacing the belts should still be possible with this variant...
no, it's not really genius: there's a certain way that the physical limitations can be achieved, and that defines where to go from there.|
Re: Riki200 August 18, 2017 03:57AM |
lkcl
i'm already using both those layouts. to interlace the belts the planes have to be inverted relative to each other in a very specific way.
ok so here's a top photo: you can see that the belts are mostly not intersecting the gantry rails, with the exception being at the ends. i did a video as well (at the end) to show you, it's *very* specific.
[snip]
[youtu.be]
...I guess I'll have to watch the video a couple of times more
...really appreciated.
Re: Riki200 August 18, 2017 03:59AM |
Re: Riki200 August 18, 2017 04:23AM |
chrigel
Wow, you're quick...
thanks a lot for the video explainer, I wouldn't have seen how specific and complicated all the corners really are! Have to think about that one, so far I am still not 100% convinced you couldn't do *both* belts as the "inverted" belt layout - but I do trust your judgement as you're the one who has the 3D simulation in front of you...I guess I'll have to watch the video a couple of times more
Re: Riki200 August 18, 2017 09:02AM |
lkcl
Re: Riki200 August 18, 2017 10:38AM |
gtj
I'm paying attention.
I've been on the hunt for for the same stepper except with dual shafts but the only ones I can find are these...
[www.digikey.com]
$60 US though. I may have to do the offset stepper with the short belt as well although I've been looking for a set of zero-backlash bevel gears to avoid the extra belt. No luck so far.
Re: Riki200 August 19, 2017 02:29AM |
