Re: Riki200 May 29, 2017 10:57AM |
Re: Riki200 May 29, 2017 11:41AM |
Re: Riki200 May 29, 2017 12:22PM |
the_digital_dentist
Two comments:
Is limited XY resolution really a problem? Using a 400 step per rev motor would double the resolution of a standard 200 step/rev motor without all the extra hardware,
i wanted to look at putting in enough gearing to consider dropping to coarser microstepping... or just to have better control over the print-head, as well as not have so much force on the belt, to achieve the same effect.Quote
but if the printer's frame isn't super rigid, higher drive resolution will be pointless.
mostly it was so that the analysis rules are burned indelibly into my own tiny brain...Quote
20x20 t-slot isn't going to be super rigid unless the printer is very small.
You're bending the very long belt around 10 pulleys. There's bound to be some non ideal behavior there- pulleys aren't lossless, belts stretch, and pulley axles tilt when belt tension is applied. Guide rails flex, and bearings have play, too. This is probably one of those situations where you'll have to build it to see if it works.
Re: Riki200 June 10, 2017 03:48AM |
Re: Riki200 June 24, 2017 07:12PM |
Re: Riki200 July 02, 2017 03:50AM |
Re: Riki200 July 05, 2017 08:45AM |
Re: Riki200 July 05, 2017 09:47AM |
Re: Riki200 July 05, 2017 10:27AM |
the_digital_dentist
Are you planning to make the corner pieces with all the pulleys and motor mounts using a 3D printer?
Re: Riki200 July 05, 2017 10:30AM |
Re: Riki200 July 05, 2017 12:42PM |
Re: Riki200 July 05, 2017 01:22PM |
the_digital_dentist
I think I'd try to take more advantage of the stiffness that the aluminum frame can provide instead of standing everything up above it and relying on the plastic, but maybe it isn't possible with the way the belts have to run.
Re: Riki200 July 05, 2017 02:37PM |
Re: Riki200 July 06, 2017 07:40AM |
the_digital_dentist
My coreXY machine is 610 mm wide (including enclosure) x 580 mm deep and has a 300x300 bed. As long as it will fit through a doorway (it does) and into my car (it does) I'm OK with it.
i have to take mine on planes. first time will be to take the prototype to shenzhen maker faire, which is the 10th-12th of november.|
Re: Riki200 July 07, 2017 04:06AM |
Re: Riki200 July 09, 2017 04:15AM |
Re: Riki200 July 15, 2017 09:42AM |
the_digital_dentist
How did you determine the size and number of reinforcements to use?
) but i tend to put at least a 5mm or 6mm flat plate on the top over to the screw holes (+/-15mm in each of x and y for a NEMA17). i also now go with 40% infill.|
Re: Riki200 July 22, 2017 04:05AM |
lkcl
okay so after mulling it over for some time i came up with this design concept:
Re: Riki200 July 22, 2017 04:41AM |
prot0typ1cal
Looks similar to my Etch-XY concept (CoreXY driven dual bar ultimaker carriage):
ok let's start by moving the extruder to the right. right-section belts shorten, left motor goes anti-clockwise (blue belt), right motor goes... anti-clockwise too, yay!
Obviously, would benefit with a stacked belt arrangement, like the C bot.
Re: Riki200 July 22, 2017 01:27PM |
Re: Riki200 July 23, 2017 12:15AM |
Re: Riki200 July 23, 2017 02:44AM |
Re: Riki200 July 24, 2017 04:59AM |
prot0typ1cal
The Flex3Drive is an awesome innovation, especially the Duo.
IMO, the Prometheus System may have an edge on filament swaps for a single nozzle.
Yet to test my Prometheus hotend (not the system), soon, still building.
[www.distechautomation.com]
You're correct about the Flexion mass, which is why I was looking at a dual cross bar solution.
Still stuck in Makerbot land at that time, so was comfortable with that style direct drive extruder.
Then hit on CoreXYU, which remedies some of the some of the negatives of a standard CoreXY.
anyway: there isn't a doubling-effect from the EdgeXY because both ends are "free" not fixed. so what pulls on one side pushes on the other.Quote
I like you're using rails, instead of rods for the outer guides, should make it beefy.
i'm only using LM6UU on the carriage because... well.... i'm praying they'll be ok, but i was also concerned about engineering design and also weight of having to put rail *and* rail-support (times four) to hold the carriage...Quote
Your printer design is unique, my compliments and encouragement.
Are you planning on using a Flex3Drive?
Haven't seen one in person, so far...
Re: Riki200 July 24, 2017 06:51AM |
Re: Riki200 July 24, 2017 10:39AM |
Re: Riki200 July 24, 2017 12:08PM |
the_digital_dentist
We have a solidoodle printer at the makerspace that had a laser cut acrylic extruder, similar to that prometheus thing. It was absolute trash. If you tightened the screws too much the plastic cracked. If you didn't tighten them enough they came loose. Stay away from anything acrylic.
Re: Riki200 July 24, 2017 02:04PM |
Re: Riki200 July 25, 2017 05:20AM |
[www.professionalplastics.com]Quote
prot0typ1cal
How about G10/FR4 garolite?
Available in blue
Re: Riki200 July 25, 2017 10:05AM |
