Re: Riki200 July 25, 2017 12:00PM |
lkcl
[www.professionalplastics.com]Quote
prot0typ1cal
How about G10/FR4 garolite?
Available in blue
niiice - you mean PCB fiberglass! that's actually a really interesting idea. it's easy to get hold of and strong as hell.
Re: Riki200 July 25, 2017 12:40PM |
lkcl
hi folks i was here over a year ago when designing and building the sandwich200 (based on the Fusebox) - i had to move and focus on a crowd-funding campaign, which i am now dealing with so i need to get back onto the 3D printer and make 10 of them, so as to have a small factory to make the parts for the crowd-funding campaign.
initially i was going to buy 10 cheap china-sourced 3D printers and have them shipped to where i am living in taiwan: turns out that the exact same printer i (mistakenly, naively) selected is one that people have actually had experience with here, so i've made a report: [forums.reprap.org] but the experience with that printer was so awful that i'm just going to have to return to a complete redesign of the Sandwich200.
Re: Riki200 July 25, 2017 02:34PM |
I'm not convinced; it seems you only proved that the yellow blocks can't skew as long as the green blocks don't move, and vice versa. The way I see it:Quote
lkcl
interestingly, prot0typ1cal, the same type of "shear" is simply not possible in the EdgeXY concept, in neither X nor Y (green or yellow blocks). let's go over it:
* push left yellow block "up", push right yellow block "down". this results in blue belt on left yellow idler trying to become LONGER (tension)... but *at the same time* because blue belt on right yellow idler is on the OPPOSITE side (top) it ALSO tries to become longer (tension, stretching). as BOTH parts of the belt cannot become longer, the result is that the twisting is RESISTED (i.e. cannot occur).
* likewise for left yellow block "down" and right yellow block "up" except now it is the red belt trying to stretch.
* similar for the green blocks except this time it is the belt fixing points doing the "resisting".
Re: Riki200 July 25, 2017 02:36PM |
prot0typ1cal
I like you re-named EtchXY to EdgeXY, makes more sense.
i didn't mean to! it was an accident, honest!one of the downsides of a 3000x1800 13in LCD, things are reaaally small...
The only issue it doesn't address is that only one motor is actively driving the carriage at +/-45 degree moves.
that's all in the fun of a CoreXY design. btw i rethought the pulley system: it *is* actually a doubling effect. the right-angle just before the attachment points had me confused.
Plus, the Ultimaker uses less belts to do the same thing, using the outer rods to spin two sets of pulleys/belts for each for the X and Y, making the optional outer CoreXY (EdgeXY) drive redundant.
... except the ultimaker-2, despite having the (small) closed loop drive belt which provides quite significant gearing (thus giving better precision and accuracy), the amount of force on the (long) belt loops is double that of the EtchXY, because the EtchXY has that double pulley system.
now, there's a trade-off here with having double the number of rods, but that's a design decision. because of the rigidity you _could_ actually knock out one set of rods and have the exact same carriage arrangement as in the ultimaker-2.
personally i'll be going with 4 6mm rods... because well... that's what i have right now, took me over a week to do the design work and printing the parts: i fink i will not throw that work and time away.
Not saying it won't work, cause obviously it will. Your analysis appears correct, and as a concept appreciate the feedback.
*thumbs*-up. well, i'm about to try it out. should take me about a week to do the CAD work. will keep you posted.
Re: Riki200 July 25, 2017 03:03PM |
benson
* Push left yellow block "up", push right yellow block "down". this results in blue belt on left yellow idler trying to become LONGER (tension), so it pulls lower green block left. At the same time, because blue belt on right yellow idler is on the OPPOSITE side (top) it ALSO tries to become longer, thus pulling upper green block right.
Re: Riki200 July 25, 2017 03:17PM |
o_lampe
So, instead of buying 10 printers with a known good reputation
( there must've been other options than the FLSUN i3 ) you decided to redesign an overly complicated printer,
although you are on a tight budget
and time-line?
If I'd been a supporter of your crowdfunding campaign, I'd be very nervous now...
Re: Riki200 July 26, 2017 03:22AM |
Re: Riki200 July 26, 2017 07:24AM |
Re: Riki200 July 26, 2017 12:46PM |
Re: Riki200 July 27, 2017 07:33AM |
lkcl
the problem is: the 2x pulley and the 4x pulley are on opposite sides (separated by 320mm). what happens, therefore, is that when the motor turns you get *twice* the force pulling on one side than on the other. what that does is create "lag" on the x/y-ends, and the whole assembly shears sideways. one x/y-end is pulled harder, that causes shear, and it's only when the force of the rods twisting in the plastic joints is builds up high enough that the *other* x/y-end starts to move.
Re: Riki200 July 27, 2017 09:30AM |
prot0typ1cal
I have to disagree and agree with benson's analysis of the edgeXY.
3. The 2x belt ratio on the yellow, and 1x on the green blocks is a minor issue, which can be compensated for via firmware.
Re: Riki200 July 27, 2017 09:48AM |
chrigel
I started off by trying to explain to myself how the EdgeXY concept works by simplifying it to remove the 2x belt ratio. Doing this I found that I could use a similar cross-belt configuration where there is - as in CoreXY - only one motor per axis:
[attachment 96604 counterbelt1-1.png]
Re: Riki200 July 27, 2017 01:13PM |
Re: Riki200 July 27, 2017 01:44PM |
prot0typ1cal
[attachment 96609 addon.jpg]
Hmm... bad.
You just unconstrained the X, basically making both axis free floating. Rotating the steppers can effect either axis.
The imaginary twist about the carriage is just as much true for a standard coreXY as the EdgeXY.
Re: Riki200 July 27, 2017 01:59PM |
Re: Riki200 July 27, 2017 02:08PM |
Inertia. Consider when the extruder is at, say, X+ limit of travel, and you're accelerating in the Y+ direction. The whole mess wants to rotate clockwise. How much a problem this is depends on how crazy you get with accelerations.Quote
prot0typ1cal
Fail to see how this twist occurs, as there isn't any force acting on the carriage, other than linear loads from the crossing rods.
Re: Riki200 July 27, 2017 05:04PM |
benson
Inertia. Consider when the extruder is at, say, X+ limit of travel, and you're accelerating in the Y+ direction. The whole mess wants to rotate clockwise. How much a problem this is depends on how crazy you get with accelerations...Quote
prot0typ1cal
Re: Riki200 July 28, 2017 02:10AM |
Re: Riki200 July 28, 2017 05:52PM |
lkcl
however it makes a 3D red-blue barrier only on one side (at the bottom).
lkcl
left yellow block shifted out a bit. for Y axis belts rotate by 90 degrees then stretch outwards a bit to fit *around* X belts. red of Y fits *underneath* blue of X and vice-versa except on that one side where there's a 3D red-blue barrier, and for that you can connect to the slightly-shifted-outwards yellow block.
Re: Riki200 July 29, 2017 02:02AM |
Re: Riki200 July 29, 2017 02:07AM |
chrigel
Hm, I have to disagree somewhat here: Since the carriages have to be connected to red on one side and to blue on the other, we unfortunately have, for most of the rails' lengths, a 3D red-blue barrier there as well.
Ok, here is me trying to draw what you said:
Note that I haven't yet found a way to avoid the belts crossing the rods, next to the left and bottom carriages... my gut feeling tells me this isn't good, what do you think?
Re: Riki200 July 29, 2017 04:43AM |
o_lampe
What bothers me in the last pic is, that you now have to tension 4 belts just right.
Re: Riki200 July 29, 2017 05:40AM |
lkcl
yep that's it! that's exactly it. regarding the blue belt crossing the rods, you can instead make the red belt attach to the far left of the yellow (left) block, and also make it the *bottom* belt. then the blue belt can run through a channel in and *over* the left yellow block.
lkcl
now the only thing is, as prot0typ1cal mentioned (sorry i haven't caught up and acknowledged what you said man!) this design relies critically on pulling one block with one belt section but that the other belt section has to handle the load of *both* blocks (it's a train/carriages effect in other words).
o_lampe
What bothers me in the last pic is, that you now have to tension 4 belts just right. It's difficult enough to equally tension two belts of a coreXY.
lkcl
now, i honestly don't know enough about the materials properties of these GT2 timing belts (not the steel ones, the fibre-reinforced ones) to say if they'll stretch significantly, but given the kinds of accelerations and speeds i want to subject this design to i don't feel confident taking a risk.
now, i do actually have some GT2 steel-reinforced belt here, i wanted to see what it's like, and it's... really really stiff. trying to get it round even a GT2-20-tooth... i'd be concerned about how much tension it would need to be under. so... *sigh* overall it's all pointing towards the low-risk etch-a-sketch layout.
Re: Riki200 July 29, 2017 06:17AM |
chrigel
lkcl
Hmmm... so initially I didn't quite understand (or where prot0typ1cal mentioned it), but I think I got it now:
The blue belt (when driven by the motor) pulls one carriage, plus the red belt which pulls the other, i.e. 2:1, right?. Well, my initial way of thinking was to use a 2:1 pulley system for the blue belts anyway, would that make a difference? I think it could easily be added to the latest picture without upsetting anything.
So if we replace the red belt with something like a cable or wire, it can change direction not only in a single plane (as a belt ideally should), but in, say, the Z axis direction as well:
Re: Riki200 July 30, 2017 03:15AM |
Re: Riki200 July 30, 2017 04:50AM |
o_lampe
@chrisgels idea to use wire instead of belt:
What happens when the critical portions of our classic CoreXY belts aren't parallel/rectingular to each other?
The belts change tension, which adds inaccuracy.
My gut feeling tells me, that the red wire not running parallel to the blue belt will cause the same inaccuracy? ( at least between idlers "d" and "c" )
Re: Riki200 July 31, 2017 02:09AM |
lkcl
it's much, much worse than that: the change in angle of the belt coming off the X-gantry and leading to the motor results in non-linear printing. even just 1mm of misalignment can result in a huge and noticeable amount of distortion.
o_lampe
Re: Riki200 July 31, 2017 02:49AM |
chrigel
Anyway, I thought lkcl had already left this idea behind anyway, so maybe we should concentrate on the designs he's still considering?
Re: Riki200 August 01, 2017 01:05AM |
Re: Riki200 August 01, 2017 01:21AM |
prot0typ1cal
Problem with the etch-a-sketch is it uses closed loops, both of different lengths on the same axis, so stretch/acceleration/harmonics will be different on both loops.
Inherently, the etch-a-sketch isn't square or parallel, not really required for a child's toy, close is good enough. Will require some degree of tuning for a 3d printer, with pulleys free to offset perpendicular to the axis to dial it in, then lock in place.
i will be taking it into account. does actually have to be true. and the frame as well. dang.
