linear rails advice for a 200x200 design May 11, 2017 01:21PM |
Re: linear rails advice for a 200x200 design May 30, 2017 06:29PM |
Re: linear rails advice for a 200x200 design June 07, 2017 07:11AM |
Re: linear rails advice for a 200x200 design June 07, 2017 12:05PM |
Re: linear rails advice for a 200x200 design June 07, 2017 07:32PM |
What do you mean by noughts and crosses?
Is that like the ultimaker arrangement?
Linear guides are traditionally selected based on the forces the blocks can withstand. Even MGN7 can survive roughly 600lb of force so when designing a printer we select on other factors.
MGN7 is too narrow to easily mount in 2020 extrusion (plus standard nuts only go down to m3) so it typically gets avoided. MGN9-15 have similar prices so you are basically making a trade between weight and rigidity.
If the rail is fixed and you have space, there is no reason not to use the largest rail. If the rail is moving you probably want the smallest rail since rigidity will be provided by the extrusion it is attached to.
The decision becomes complicated if the rail is unsupported, since in that case you probably want to do the math or FEA to see how much bending to expect. Unsupported rail is not ideal design because the holes drilled into the rail dramatically reduce its strength.
In unsupported applications you are probably better off buying name brand linear shaft and bearings instead. Linear shaft is also available in hollow or ceramic coated aluminum variants when weight matters. Ebay junk on out of spec drill rod is not representative of the performance you can achieve with properly chosen components. The real thing is very smooth.
For example misumi part number PSPJ10-280 is $13/ea and is almost certainly lighter and more rigid than unsupported MGN9 rail.
Re: linear rails advice for a 200x200 design June 13, 2017 06:15AM |
