Leadscrew driven XY gantry printer?
Posted by klcjr89
March 21, 2018 09:23PM
I have been thinking about which way I want to go in designing my next printer. I found this video on YouTube: [youtu.be] Picture if you can't watch the video:
Which shows a leadscrew driven crossed bar XY gantry.
I think I want to implement this design, except without moving the mass of the motors like in the video above shows.
I had an all leadscrew driven axes i3 style printer and it worked very well. It printed and traveled very fast even with TR8x8 leadscrews which is attributed to the 120kHz step frequency I had set in Smoothieware, low inertia motors, and 24V power.
I sold this printer and am wanting to build something from scratch this time.
Using the leadscrews got rid of ringing and ghosting artifacts (especially on the moving bed with 1/4" Mic-6 bed). There was no backlash with the leadscrews using these adjustable Delrin nut blocks:
I ruled out ballscrews long ago due to their increased size, weight, and harmonics transferred through the ballnut.
Is there anything I should watch out for or any 'gotchas'?
Unlike my other threads on the other designs I've posted, I have decided I want to keep the gantry fixed and at the top of the printer, with the bed moving in Z to keep the amount of moving wires to a minimum.
I will incorporate the_digital_dentist's three point leveling for the bed.
I am evaluating using these linear guides which I've only seen SublimeLayers use on a delta printer: Note, this image is a Chinese clone, in my build I would be using the genuine LM76 (USA) ones.
These use three bearings, two fixed and one on an eccentric. This style of linear guide has been proven on CNC machines and plasma tables.
Planned extrusions will be Misumi 30x30mm GFS series (thicker cross section).
Edited 19 time(s). Last edit at 03/22/2018 01:10PM by klcjr89.
Re: Leadscrew driven XY gantry printer?
March 22, 2018 04:54AM
Will be interesting to see, how?
My first idea was: bevelled gears and a keyed smooth rod to drive the bevelled gear.
gtj
March 22, 2018 08:40AM
o_lampe
So the "differential" slides along the keyed drive rod? Could be cool. Maybe use a square shaft rather than a keyed round one?
March 22, 2018 11:00AM
o_lampe
Pretty easy, just dual leadscrews coupled with a belt for each axis. Think of the ultimaker, but with leadscrews. No keyed shafts or anything should be necessary.
Edited 2 time(s). Last edit at 03/22/2018 11:02AM by klcjr89.
March 22, 2018 12:06PM
gtj
o_lampe
Square shaft that runs in standard bearings would be nice.
@klcjr89
I can't picture it, can't wait to see a drawing... smiling smiley
Edited 1 time(s). Last edit at 03/22/2018 12:07PM by o_lampe.
March 22, 2018 03:23PM
Here is what I'm thinking of for the frame design.
Extrusions are Misumi 30x30 GFS 6 series. Frame dimensions: Approximately 1500mm x 700mm wide (square).
Leveling feet/wheels will be added to the base legs. Uninterruptable power supply will be mounted in the bottom area.
Side enclosure panels will be polycarbonate.
Edited 4 time(s). Last edit at 03/22/2018 03:39PM by klcjr89.
March 24, 2018 11:06PM
I recall lkcl planning to build a printer similar in concept. He wanted to use belts, thought but the placement of the driving force was the same (the belts/screws apply force very close to the X intersection). He ended up having an issue with binding when the XY assembly was further off center, it would cause a moment on the perimeter bearings since you're pulling/pushing close to one set of bearings than the other.
March 24, 2018 11:10PM
Trakyan
My plan was for the leadscrews to drive the 'outer perimeter' of the XY plane. Imagine, four Hiwin guides and two leadscrews synchronized with a belt per axis. There would be two more Hiwin guides to make up the 'crossed bar' printhead mechanism.
Edited 3 time(s). Last edit at 03/24/2018 11:12PM by klcjr89.
March 25, 2018 02:12PM
I used 40x40 mm t-slot for a similar sized frame and ended up adding some aluminum plate corner bolsters to the sides of the frame because the moving mass in the Y axis was moving the frame a bit more than I was happy with. The dual layer PC enclosure panels I used don't attach rigidly to the frame (they are just cut to fit inside the slots) so they don't help with frame rigidity. They are very light weight and provide thermal insulation as well as light transmission.
I used skate wheels on the front legs, and leveling feet on the rear, all of which which make it very easy to move the machine around, except for going up and down stairs. I'm watching for a deal on some larger wheels to make that easier.
gtj
March 25, 2018 04:13PM
Interesting application of cable chain. smiling smiley
It doesn't bind when both ends are close to each other in XY?
March 25, 2018 04:47PM
It is laid out in a big circular loop. The frame attached end opens toward the front of the printer and the extruder carriage end opens toward the rear of the printer. That keeps the radius of curvature relatively large which should minimize wire failures due to excessive flexing. It's a little dark but you can see what it's doing in this picture:
gtj
March 25, 2018 05:20PM
the_digital_dentist
Gotcha, thanks!
