Black Beauty Build Log May 24, 2018 10:52AM |
Re: Black Beauty Build Log May 25, 2018 03:13AM |
Re: Black Beauty Build Log May 27, 2018 01:20PM |
Re: Black Beauty Build Log May 27, 2018 05:24PM |
o_lampe
Nice!
How much did you get for placing the Duet sticker in the picture
Archiclem
Really like the igus rails! Can't wait to see the final mount! How much does they cost?
Side Panels May 27, 2018 05:36PM |
Re: Black Beauty Build Log May 28, 2018 02:18AM |
Re: Black Beauty Build Log May 28, 2018 10:04AM |
Z Axis Supports May 28, 2018 02:04PM |
Re: Black Beauty Build Log May 28, 2018 03:46PM |
Re: Black Beauty Build Log May 29, 2018 04:00PM |
NathanaelXYZ
You mention that you're using CF-HTPLA for the printed parts-- I'm interested to see how that will end up working out in the long run.
Z Axis Supports June 03, 2018 12:40PM |
Re: Black Beauty Build Log June 03, 2018 01:11PM |
Re: Z Axis Supports June 03, 2018 06:23PM |
Re: Black Beauty Build Log June 03, 2018 08:19PM |
The Dremel gods have demanded a sacrifice... June 03, 2018 08:23PM |
The XY gantry is back in place June 03, 2018 08:29PM |
Re: Black Beauty Build Log June 04, 2018 07:40AM |
Re: Black Beauty Build Log June 04, 2018 10:14AM |
the_digital_dentist
The bed shouldn't be "floating" on the springs, and they aren't there to protect against a "head-crash". They are there to ensure that the bed is pushed firmly against the heads of the leveling screws (or the nuts, depending on how you've assembled things).
the_digital_dentist
I used a kinematic mount for the bed in my last printer- the springs hold the bed down on the leveling screws instead of pushing it up. In theory, gravity alone is sufficient to keep the bed in position, but I transport the machine laying on its back and needed the springs to ensure it would stay put. I print on a 0.7 mm thick piece of PEI stuck to the aluminum bed plate. The kinematic mount allows the bed to expand without creating any lateral forces that cause things to bend. See: [drmrehorst.blogspot.com]
the_digital_dentist
That tee-shirt is why I always work naked, protected by a thick layer of vaseline....
Re: Black Beauty Build Log June 04, 2018 10:58AM |
Re: Black Beauty Build Log June 04, 2018 11:27AM |
the_digital_dentist
Most glass doesn't expand much at the temperatures a print bed operates, so it may not be needed. OTOH, if you use glass on top of a piece of aluminum you have to think about what the aluminum is going to do.
Re: Black Beauty Build Log June 12, 2018 06:33PM |
Re: Black Beauty Build Log June 13, 2018 12:04AM |
Re: Black Beauty Build Log June 13, 2018 11:37AM |
the_digital_dentist
It looks pretty good. When will it be printing?
Re: Black Beauty Build Log June 13, 2018 03:09PM |
Re: Black Beauty Build Log June 13, 2018 03:38PM |
the_digital_dentist
You can print PLA on unheated blue painter's tape for testing without the bed heater.
Re: Black Beauty Build Log June 13, 2018 03:51PM |
Re: Black Beauty Build Log June 13, 2018 03:59PM |
I can "Air Print" ![]() June 15, 2018 09:33PM |
Re: I can "Air Print" ![]() June 16, 2018 02:08AM |
Re: I can "Air Print" ![]() June 16, 2018 06:58AM |
