Printer Design with Bearings on Extrusions
Posted by gmedlicott
November 26, 2018 01:06AM
A while back I designed a printer that was to be the base for a printer farm after trying to use a upgraded Folger FT5 for that purpose. The printer is designed to be easily extendable in the X (or Y) dimension. It uses 623zz bearings that ride on the extrusions for all motion constrain.
I finally wrote up a blog post here:
https://www.tolen3d.com/blog/designing-a-printer-farm-unit
I'm in the middle of a complete redesign, so comments welcome!
Re: Printer Design with Bearings on Extrusions
November 28, 2018 02:11AM
How do you adjust the bearing clearance? Using eccentric screw posts or do you add some tensioners in the brackets?
Most people would be afraid of the noise coming from naked bearings on extrusion.
November 28, 2018 10:20AM
Those steel bearings are going to start eating away at the softer aluminum they’re riding on.
November 28, 2018 12:30PM
o_lampe
The printed parts are very rigid, and are designed so the bearings have a light pre-load. It takes an accurate printer, and measuring the extrusion dimension to make it work.
o_lampe
I was worried about the noise too, but it actually isn't that loud. The Nema 17 motors are much louder using a 16/32 microstep driver. It may be more audible with Trinamic drivers.
November 28, 2018 12:58PM
FA-MAS
Another concern I'm looking into, though the bearings in this setup have a light preload (20N maybe for the X&Y, 50N for the Z) and have purely rolling motion vs rolling-sliding as found in V-wheels. Also aluminum extrusion is anodized which increases hardness. Even so, I'm working on a preload vs wear test to determine a max acceptable preload.
November 28, 2018 03:26PM
If I were contemplating enough production to justify a printer farm, I don't think I would rely on bearings held in printed plastic mounts. I think I'd end up spending more time repairing the machines than printing. Would it really be difficult to make the part from a drilled piece of metal?
November 28, 2018 03:53PM
the_digital_dentist
Having come from a background of designing parts for CNC machining, plastic (printed or other) is amazing, I can design semi-complex parts and added features are free! That said, 3d printing parts can be a bit weak, and are not always dimensional accurate. Now injection molding on the other hand...
November 29, 2018 03:53AM
Any video ?
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
November 29, 2018 06:39AM
the_digital_dentist
Of course you would.
Why does it matter?
November 29, 2018 06:58AM
gmedlicott
They don't look rigid at all and in fact luckily they are not as the whole set up would have the bearings eat in the Al extrusion or bind. The X, Y connecting part is particularly flimsy.
November 29, 2018 09:24AM
Number_5
the_digital_dentist
Why does it matter?
Of course I would what? Why does anything matter?
November 29, 2018 01:20PM
MKSA
gmedlicott
The carriage parts are rigid in design (relative, 3d printing vs. CNC machining) as there is always material directly connecting opposing bearings, with the bearing preload set by elastic deformation. The Z for instance has a preload of 50N, enough so the bearings ride smoothly on the extrusion, yet stiff enough for the bed to tolerate a lopsided print at large volume.
The X-Y interface does look weak, but it has M6 x 120mm through bolts with the side carriage parts having locking tabs to prevent rotation. I can grab the ends of the lower Y rail and barely rock it, with much more force than the print head would exert. This design is simple but has its downsides as described in the blog post at the top of the thread.
This build was more an exercise in seeing what worked and what didn't. Many lessons learned as all of us can probably attest to when building our printers!
