Beware : Extruded profiles can be bended or twisted, while remaining standard ! January 29, 2019 12:31PM |
Re: Beware : Extruded profiles can be bended or twisted, while remaining standard ! January 29, 2019 03:11PM |
M_Xeno
For direct guidance on the profile applications (as is often the case with deltas), it would be necessary to be able to sort the straight copies. If the extrusion supports another linear guide, such as the ubiquitous MGN12, special profiles should be used for this application, milled after extrusion, as proposed by MISUMI.
Re: Beware : Extruded profiles can be bended or twisted, while remaining standard ! January 29, 2019 07:52PM |
Re: Beware : Extruded profiles can be bended or twisted, while remaining standard ! February 04, 2019 03:33PM |
Although the allowable tolerances are quite broad, extrusions are often straighter than they are rigid. I've put several lengths of Misumi extrusion against a surface plate and I've never been able to get a feeler gauge below it.
