BOB Simpson development December 28, 2013 05:17AM |
nicholas.seward
I have been considering building the ultimate RepRap machine. The machine would use nothing but PLA for the whole robot with the exception of string, limit switches, steppers, controller board, and the hot end. I am dubbing the concept BOB Simpson (BOltless and Bearingless).
I have the basics all mapped out. (Lashed geared double lamina compliant joints, proportional gear drive joints, gear bearings for pulleys, etc.) There is still a lot of work to do. How do you make a solid stepper mount without bolts? How do we tension the string without any vitamins? I want to print everything in small sections (To avoid a heated bed) directly on existing surfaces so we can avoid the need for a none-PLA build platform.
Time is tight and this isn't high on my list right now so I thought I would give the bounty system a try. I set the goal pretty high at $5000. I asked myself how much money would I need to get it to be on the top of my list.
This is an experiment in how the bounty system will work for something like this. Let's find out.
BOUNTY LINK
For this to work, you need to pledge if you want this to happen AND you have to use your contacts to solicit more support. I would imagine that if only the people that see this post pledge then this won't work.
Re: BOB Simpson development December 28, 2013 10:57PM |
Re: BOB Simpson development December 29, 2013 09:50PM |
Re: BOB Simpson development January 09, 2014 04:44PM |
