Rostock Parts no where to be found. April 28, 2014 01:21PM |
Re: Rostock Parts no where to be found. April 29, 2014 08:43AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Rostock Parts no where to be found. April 29, 2014 10:03AM |
Re: Rostock Parts no where to be found. April 29, 2014 10:51AM |
Re: Rostock Parts no where to be found. April 29, 2014 11:09AM |
pangkahang
beside the plastic parts, is there anything you need to source?
And where a you located?
Re: Rostock Parts no where to be found. April 29, 2014 11:15AM |
Well any printer you build will need other parts. Almost everything you need can be found in my shop. I'm located in the Netherlands but ship worldwide. Check [www.builda3dprinter.eu] for all the information you need.Quote
pangkahang
Re: Rostock Parts no where to be found. April 29, 2014 11:42AM |
Re: Rostock Parts no where to be found. April 29, 2014 12:16PM |
Re: Rostock Parts no where to be found. April 29, 2014 01:21PM |
Vinculum
Agreed. I understand the ambition and can only say wow! But I think that you will create more problems than solve any. Delta's are great for speed and high acceleration. By going all metal you loose all those qualities. And chains instead of belts? Shivers down my spine. Chains are way more clunky, heavy and are very bad for tight corners which you need (2 180 degree turns above and below). Ambitious? Yes. Cool? Most definitely! Practical and useful? I doubt it.
Re: Rostock Parts no where to be found. May 03, 2014 07:34PM |
Re: Rostock Parts no where to be found. May 05, 2014 11:24AM |
jaydmdigital
You seem pretty sure it'll all work out....if you are using any other experience as a basis for your optimism you are going to get a rude awakening. Please do blog your progress, you have ideas that will be interesting to see the results of. We should all be able to learn something.
Re: Rostock Parts no where to be found. May 07, 2014 07:23PM |
Re: Rostock Parts no where to be found. May 08, 2014 11:57AM |
Re: Rostock Parts no where to be found. May 08, 2014 04:52PM |
