Rostock Build Log May 20, 2014 10:50AM |
Re: Rostock Build Log May 20, 2014 05:24PM |
Re: Rostock Build Log May 22, 2014 02:55PM |
Re: Rostock Build Log May 22, 2014 02:58PM |
Re: Rostock Build Log June 01, 2014 11:24AM |
Re: Rostock Build Log June 02, 2014 02:56PM |
jaydmdigital
I read your blog. Are you a mechanical engineer? I have concerns about the friction of the belt on the fender washer.
On the endstop switches, the ones you have are meant to plug into the S - + on the RAMPS and have their own pull up resistor on the circuit board (along with a LED). When you flipped the connector, you shorted - and + which took out the fuse on your Arduino. Any high quality snap switch (Cherry is a good brand) mounted in a fixed spot as high up as it can go will work.
On the adjustable endstops M666 is a Gcode (if using Marlin) you should get familiar with. It allows software adjustment as small as you like though I only go to 0.01mm increments myself. I just posted a video of how I calibrate manually (https://www.youtube.com/watch?v=tDLbqLve128).
If you are using Repetier FW I have another video (https://www.youtube.com/watch?v=uDB4hE6nyYI)
Re: Rostock Build Log June 03, 2014 06:44PM |
Re: Rostock Build Log June 04, 2014 10:42AM |
