Calculating rods length and radius for X Y and Z towers July 28, 2014 05:41AM |
Re: Calculating rods length and radius for X Y and Z towers July 28, 2014 11:15AM |
Re: Calculating rods length and radius for X Y and Z towers July 31, 2014 07:55AM |
Re: Calculating rods length and radius for X Y and Z towers July 31, 2014 01:08PM |
jaguarking11
This is what I used for my printer. You don't have to be 100% acurate on the rod lengths, however you do have to be very accurate to match the rods to each other as close as possible. I have roughly .1-.2mm difference in mine, its as close as I could get. I am also using solid alu drilled and tapped. I recommend CF tubes instead. Not as expensive as you think. If you need some pointers, my printer is a one of, and it is printing properly as of last night. Check out my blog in my sign it may help you on your adventures.
Re: Calculating rods length and radius for X Y and Z towers July 31, 2014 01:35PM |
