Nozzle size? The effect of it? October 07, 2014 04:41PM |
Re: Nozzle size? The effect of it? October 07, 2014 05:21PM |
Re: Nozzle size? The effect of it? October 07, 2014 05:36PM |
Re: Nozzle size? The effect of it? October 08, 2014 02:50PM |
jaguarking11
I am thinking of 50-60% of the orifice size is doable. However that would require me to run .8mm filament. probably have to ramp up the temps in the 260c range or higher to do so as well as increase speed.
Re: Nozzle size? The effect of it? October 08, 2014 03:52PM |
Re: Nozzle size? The effect of it? October 08, 2014 05:43PM |
Re: Nozzle size? The effect of it? October 10, 2014 11:00AM |
jaguarking11
The reason I went with 1.75mm filament is because its becoming the standard. With a proper drive mechanism its reliable, light and has more options as of today.
I think I may just buy a all metal j-head that has brass removable nozzles and a few nozzles/drill bits as well varying from .6mm to .8mm or even 1mm. That should make it easy to replace the nozzles and speed up my prints while layering .4mm and above.
Re: Nozzle size? The effect of it? October 10, 2014 12:11PM |
Re: Nozzle size? The effect of it? October 14, 2014 09:00AM |
Re: Nozzle size? The effect of it? October 14, 2014 11:18AM |
Re: Nozzle size? The effect of it? October 17, 2014 10:28AM |
