Bed-Holder for Rostock Delta Mini Pro
Posted by Replace
November 15, 2014 06:03PM
For my CZAR Rostock Delta Mini Pro machine,
I designed this, to keep the default acrylic buildplate fixed to the machine bottom, with 6 small magnets.
The magnets clamp to the original stepper mounting bolts :-)
This is how it looks:
Of course, you must have another printer to print it, due to it's size, but I still have my Orca :-)
Thomas
Edited 4 time(s). Last edit at 11/16/2014 08:54AM by Replace.
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Bed-Holder for Rostock Delta Mini Pro
November 27, 2014 01:22AM
Great work, I really missed something like that at the beginning when the buildplate was tilting on the three rubber legs consistantly.
I assume this is your model on Thingiverse ?
Would you mind sharing source file so we can modify it ?
All about delta 3d printers in one place [www.deltarap.org]
November 28, 2014 12:18PM
Yes, that's my design.
However, It need some fine tuning (work in progress as you could see :-)
For now I had some warping in the first print and the holes to slip over the build plate bolts were a bit to tight.
After rework of the model and a successful print, I will publish the code (which is OpenScad btw).
Thomas
