hello, my name is Björn and a few days before, i bought a Kossel Mini (t3dp3d). that one was used and still working very fine. after the kalibration i began to print ant all worked very well for a few days, then i decided to print some larger Project, and start up with some tiles of the 3D Catan (http://www.thingiverse.com/thing:26979/#files)
after 6 Tiles, suddenly the Autolevel seems to be incorrect. without the autolevel command, the Printer works without any Problems, but with the autolevel command. the Printer first layer isn#t in the same high at al positions at the bed. i thougt it was just a mechanical Problem or the printer was to hot? or maybe thomething else. after a few hours i tried again and there was the same Problem. i don't change anything, naighter the mechanics nor the software.
i used some oil for al of the moving parts and reflash the firmware. the problem was still there.
after that i readjust the Z_high and change the value about 0.1 and now the printer does his job but i can still see the same problem.
please can you help me? i dont understand that it happens just between one print out and another.
Björn
Edited 1 time(s). Last edit at 04/04/2015 05:04AM by nimrod.
