Confusion over carbon tubes May 07, 2015 11:38AM |
Re: Confusion over carbon tubes May 07, 2015 11:47AM |
Make_3D
First of all I apologize if this is a stupid question.
I need help clearing up some confusion I have regarding carbon fibre tubes with traxxas rod ends. Basically I am building my first delta printer based on the Griffin printer, I have purchased some carbon fibre tube (6mm OD x 4mm ID) and Traxxas 5347 Rod Ends. I have tapped some threads into the rod ends and purchased some m4 threaded and inserted it into the newly threaded rod ends. Up until this point everything was running smoothly, I watched several videos on how to thread the tubing only to discover that there wouldn’t be any point threading the tube as I can insert the threaded rod (with the rod end) into the tube without any pre tapping. Here is where I am stuck, with the tube having an ID of 4mm and the threaded rod in the ends being 4mm the rod was never going to be bigger enough to require me to tap the tube. Have I made a mistake somewhere along the line? How am I supposed to attach the rods ends to the tube? I don’t like the idea of just using glue as I will be using a heated bed and wouldn’t want the glue to soften / melt due to the heat?
Thanks
Re: Confusion over carbon tubes May 07, 2015 01:11PM |
Re: Confusion over carbon tubes May 07, 2015 08:04PM |
Re: Confusion over carbon tubes May 08, 2015 03:21AM |
