Building a Rostock Delta, need someone with experience May 08, 2015 04:19AM |
Re: Building a Rostock Delta, need someone with experience May 09, 2015 09:03AM |
Re: Building a Rostock Delta, need someone with experience May 09, 2015 10:47AM |
Re: Building a Rostock Delta, need someone with experience May 09, 2015 02:49PM |
Re: Building a Rostock Delta, need someone with experience May 09, 2015 05:00PM |
Re: Building a Rostock Delta, need someone with experience May 09, 2015 11:07PM |
mrg78
Hi !
I have built 2 rostocks and been calibrating and modifying it for about a year, i might be able to help some.
the main thing i thing you should consider, don't build to high, and if you do, build it sturdy.
I built my first with print height about 400mm with only two wooden boards in the same direction, i should add another in the opposite direction so it wouldn't wobble.
Original joints in plastic caused some problem for me, on the outer regions the print got cramped together, got a post about it here on the forums
Changed to magnetic that is much more stable, but buy strong magnets, no china-crap, been there, done that
But i really like my printer and wouldn't choose another design, maybe kossel but still delta.
///Mats, Sweden
Re: Building a Rostock Delta, need someone with experience May 10, 2015 03:28AM |
Re: Building a Rostock Delta, need someone with experience May 10, 2015 03:29AM |
Re: Building a Rostock Delta, need someone with experience May 11, 2015 08:33AM |
mrg78
Yeah, i used 1 meter rods as well, but since they stick out on each side you can just let the stick out even more on the top, and maybe cut them of if there in the way.
But if you build it really sturdy it may not be a problem for full 1 meter height, i guess.
It is pretty important to get the angles exact on the baseplate and top.
I printed the drawing on a A1 printer and drew from that on the board, put two boards together and used a band saw so they where exactly the same.
A friend of mine used a jigsaw to cut but it didn't turn out straight, I don't recommend using that.
AndrewBCN
mrg78
the main thing i thing you should consider, don't build to high...
///Mats, Sweden
TehStranger
Should I just stick to 762mm?
Yes.
Re: Building a Rostock Delta, need someone with experience May 11, 2015 01:51PM |
Re: Building a Rostock Delta, need someone with experience May 12, 2015 12:37AM |
mikes3ds
What type of motor is it? (Data sheet will say something about the max current)
Also what type of driver do you have?
This is a nice guide, [reprap.org]
Re: Building a Rostock Delta, need someone with experience May 12, 2015 01:39AM |
Re: Building a Rostock Delta, need someone with experience May 12, 2015 03:45AM |
mikes3ds
Servo:
Rated Current: 1.2A (That is what the ebay site says; however, I like looking at the datasheet as well)
ITrip can be equal or lower than current rating.
Resistor
Rs=0.2 ohm (StepStick)
Vref = I_TripMax * 8 * Rs
Vref = 1A * 8 * .2
Vref = 1/6
Just follow a video or this on how to do it [reprap.org], its really easy.
Re: Building a Rostock Delta, need someone with experience May 12, 2015 02:09PM |
