Trouble getting Z-probe auto-calibration to work on Kossel/Duet May 16, 2015 07:36PM |
Re: Trouble getting Z-probe auto-calibration to work on Kossel/Duet May 17, 2015 03:43AM |
Re: Trouble getting Z-probe auto-calibration to work on Kossel/Duet May 17, 2015 11:01AM |
Re: Trouble getting Z-probe auto-calibration to work on Kossel/Duet May 17, 2015 03:50PM |
blakebart
Thanks as always for the quick reply. It's working now. In the config.g file I was using, the H parameter of the M558 command was not there, so I fixed that. I just checked the config.g file in your RepRapFirmware-dev fork and the H parameter is there, so I was using an older release. Still it was good to go through this exercise and learn about some subtleties.
Re: Trouble getting Z-probe auto-calibration to work on Kossel/Duet May 17, 2015 05:17PM |
Re: Trouble getting Z-probe auto-calibration to work on Kossel/Duet May 17, 2015 05:33PM |
blakebart
The next area I'd like to understand is axis compensation. I've seen that people print cubes and verify dimensions but I think the point of axis compensation is to make sure surfaces that are supposed to be orthogonal to each other are. Do you have a recommended object for making the measurements to put into the 556 parameters?
Re: Trouble getting Z-probe auto-calibration to work on Kossel/Duet May 18, 2015 12:58AM |
