Not quite understanding z probe
Posted by Ben.folkes
May 27, 2015 05:57PM
I'm trying to fix my friends cherry pi delta iii and when I home and then use G29 to z probe, everything looks fine and the nozzle then moves to 0,0,20. When I lower it by 20mm in the z so it should be at 0, I can see a gap between the nozzle and bed. Please could someone explain how I adjust this. Thanks very much.
Ben
Re: Not quite understanding z probe
May 27, 2015 07:24PM
Measure the size of the gap, then in your firmware config increase the setting for the probe Z offset or trigger height by that amount. How you do that depends on what firmware you are running.
May 29, 2015 03:46AM
Hi I'm using marlin and when I increase the z probe offset value even by 10mm, it makes no difference to where it thinks z=0 is after running g30. I'm really confused, does the z probe need to be deployed at the start of every print? Cheers for all the help
