Tutorials for first printing? May 30, 2015 03:49PM |
Re: Tutorials for first printing? May 31, 2015 06:41AM |
Re: Tutorials for first printing? June 01, 2015 05:09PM |
Re: Tutorials for first printing? June 01, 2015 07:03PM |
Re: Tutorials for first printing? June 02, 2015 03:01PM |
When you're done setting up Printrun, you can start pronterface.py in the directory you unpacked it. Select the port name you are using from the first drop-down, select your baud rate, and hit connect. Load an STL (see the note on skeinforge below) or GCODE file, and you can upload it to SD or print it directly. The "monitor printer" function, when enabled, checks the printer state (temperatures, SD print progress) every 3 seconds. The command box recognizes all pronsole commands, but has no tabcompletion.
If you want to load stl files, you need to install a slicing program such as Slic3r and add its path to the settings. See the Slic3r readme for more details on integration.
Re: Tutorials for first printing? June 02, 2015 06:48PM |
Re: Tutorials for first printing? June 03, 2015 12:01AM |
