Little Help? - Rostock Mini July 04, 2015 09:01AM |
Re: Little Help? - Rostock Mini July 04, 2015 10:53AM |
Re: Little Help? - Rostock Mini July 04, 2015 12:11PM |
#define TEMP_SENSOR_0 0 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_BED 0No longer getting an error on Arduino IDE Serial Monitor. The board doesn't seem to be getting any command past the initial status "echo"s
Re: Little Help? - Rostock Mini July 04, 2015 12:14PM |
start echo: External Reset Marlin1.0.2 echo: Last Updated: Jul 4 2015July 3, 201506:10:27 | Author: (G-Tek, Default Config) Compiled: Jul 4 2015 echo: Free Memory: 5206 PlannerBufferBytes: 1232 echo: Hardcoded Default Settings Loaded echo: Steps per unit: echo: M92 X44.44 Y44.44 Z44.44 E836.00 echo: Maximum feedrates (mm/s): echo: M203 X100.00 Y100.00 Z100.00 E25.00 echo: Maximum Acceleration (mm/s2): echo: M201 X9000 Y9000 Z9000 E10000 echo: Acceleration: S=acceleration, T=retract acceleration echo: M204 S300.00 T300.00 echo: Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E5.00 echo: Home offset (mm): echo: M206 X0.00 Y0.00 Z0.00 echo: Endstop adjustement (mm): echo: M666 X0.00 Y0.00 Z0.00 echo: Delta settings: L=delta_diagonal_rod, R=delta_radius, S=delta_segments_per_second echo: M665 L250.00 R117.50 S100.00 echo: PID settings: echo: M301 P22.20 I1.08 D114.00
Re: Little Help? - Rostock Mini July 04, 2015 01:09PM |
