Kossel - all axes calibrated, but height is wrong March 10, 2014 08:07AM |
#define DELTA_DIAGONAL_ROD 228 // mm #define DELTA_ALPHA_A 210 #define DELTA_ALPHA_B 330 #define DELTA_ALPHA_C 90 #define DELTA_MAX_RADIUS 150 #define DELTA_RADIUS 94.6 #define DELTA_HOME_ON_POWER 0
#define DELTA_DIAGONAL_ROD 228.0 #define DELTA_SMOOTH_ROD_OFFSET 134 #define DELTA_EFFECTOR_OFFSET 19.9 #define DELTA_CARRIAGE_OFFSET 19.5
Re: Kossel - all axes calibrated, but height is wrong March 10, 2014 02:11PM |
Re: Kossel - all axes calibrated, but height is wrong March 11, 2014 03:30AM |
Re: Kossel - all axes calibrated, but height is wrong July 20, 2014 10:24AM |
Re: Kossel - all axes calibrated, but height is wrong July 20, 2014 04:56PM |
Re: Kossel - all axes calibrated, but height is wrong March 13, 2015 07:27PM |
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 04:44AM |
AdrianW
I am having some similar issues.
My X and Y are calibrated almost perfectly. However my Z hight is about 6% off. I can make a 25mm cube. The hight is 26.35mm. The X and Y are 25.00+/-.03. If my steps/mm where 80 insted of 100. I should see 31.25. I tightened belts and verified my that my steps/mm to be 100.
Anybody have an Idea where I should go next?. I am thinking my current setting may be wrong.
I am using RAMPs 1.4 with 16x micro microstepping.
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 05:17AM |
AndyCart
(Current steps/mm / target height) x actual height = correct steps/mm
(100 / 25) x 26.35 = 105.4
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 05:18AM |
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 05:28AM |
dc42
AndyCart
Surely it's the other way round? He wants fewer steps, not more, so he needs to reduce his steps/mm to 25/26.35 x 100. But it still gives an odd number.
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 08:58AM |
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 09:44AM |
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 10:43AM |
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 10:49AM |
AdrianW
dc42,
I have measured the belts, and the pulley teeth. all as it should be, 100 steps/mm. I have read that MakerGeek may have given me the wrong motors. The current for these is around 400mA in steed of the suggested 1500mA.
The jerk and acceleration is a good Idea. However, I run the printer very slow because the extruder can't keep up.
Re: Kossel - all axes calibrated, but height is wrong March 14, 2015 11:25AM |
Re: Kossel - all axes calibrated, but height is wrong March 15, 2015 01:53PM |
Re: Kossel - all axes calibrated, but height is wrong March 18, 2015 08:52PM |
Re: Kossel - all axes calibrated, but height is wrong May 14, 2015 03:35AM |
Re: Kossel - all axes calibrated, but height is wrong August 04, 2015 06:29PM |
Re: Kossel - all axes calibrated, but height is wrong August 10, 2015 05:37AM |
Re: Kossel - all axes calibrated, but height is wrong August 10, 2015 09:05AM |
o_lampe
I´m confused about the 17/16 teeth counts...
Do I count the teeth of the pulley or the dents? Because a 17 tooth pulley would have 16 dents, right?
o_lampe
Is it worth using smaller pulleys, like 12 or 10 teeth?
Re: Kossel - all axes calibrated, but height is wrong September 07, 2015 12:43AM |
