Benefits / Drawbacks of Metal Effector Plates
Posted by Kurzaa
September 17, 2015 04:19PM
Just received an email today from Utlibots that they are now carrying metal kossel parts, including the effector plate and a groove plate for the hotend.
While I understand the benefits of metal corners from the frames, I would think the added weight of a metal effector plate over a laser cut or printed plate would be detrimental to the printer. Is this something I should look into for my Rostock Mini, assuming the arm widths are similar?
Re: Benefits / Drawbacks of Metal Effector Plates
September 17, 2015 05:05PM
First thing that comes to my mind is you get better stability of the hotend at higher speeds/accelerations.
Might be wrong about this though.
Gonna try for my self, ordered a metal effector from robotdigg a couple of days ago.
I would like to see a metal effector that goes with balls/magnets though, where you fasten the balls to the effector and have the magnet inside a PTFE-cone on the rod.
Edited 1 time(s). Last edit at 09/17/2015 05:08PM by Koenig.
September 17, 2015 06:41PM
Watch this video and pay close attention to the effector an extruder..
[m.youtube.com]
I dont think the weight you are referring to is detrimental.
It may even improve print quality.
September 17, 2015 10:19PM
I see them on Ultibots and Aliexpress, and other places.
But I have yet to find a CAD drawing - it's hard to order something if I don't know it's going to fit!
September 18, 2015 03:46AM
My aluminum effector weighs 22 grams by itself. Adding the ball bearings (14mm) and magnets bring the weight up to 110 grams. It's more than rigid enough, so I could probably shave a couple more grams from the effector, but it wouldn't change the overall weight enough to make it worth the effort.
Here's a shot of it with a Prometheus hot end attached.
September 18, 2015 04:40AM
thetazzbot
[m.youtube.com]
I looked at the video and I do not see your point. The print speed is extremely low for a delta printer. What they are showing is not what we would like to see.
The bowden tube is nicely short. There should be less problems with retraction setup. And the bowden still isolates the stepper from high frequency speed changes which do not span a big distance. That is good. It should be able to print pretty fast at least the small infill areas. But it is not shown on the video.
What we would like to see how it behaves when it is doing:
  • high speed and high acceleration infill of small areas
  • long and fast non-printing moves (about 200 mm long at about 250-300 mm/s and at least 7000 mm/s²
Assuming you eliminated all the unwanted play in the printer, then the weight is one of the most important factors for high quality quick printing. The other ones are: the dynamic moment you can pull out from your steppers, belt/string young's modulus, frame rigidity, linear movement system rigidity.
I doubt that platform rigidity is a problem compared to the ones I mentioned above. I can tell that the traditional rostock has the biggest problems with:
  • diagonal rods (we need proper tight angle (ball) joints)
  • frame is not stiff enough
  • smooth rods are not stiff enough (they should be at least Ø12 mm)
  • betls have too low young's modulus (they are too springy); and this is the original T2.5 steel core belts, GT2 glass core belts are much worse; spectra is better than glass but worse than steel
  • I did not evaluate the stepper dynamic moment, there may be a problem there too, for now I just run them at as high current as I can
The platform rigidity is negligible compared to the above problems. And you can make your ABS platform easily more rigid. Just make it thicker. Strength of a part grows roughly with square of its thickens.
September 18, 2015 04:43AM
Ezrec
The Robotdigg Alluminium effector weighs 36 grammes and is 39.7 mm accros the ball mounting points and follows the Mini Kossel printed one almost exactly the centre hole is 16mm same ad a J-Head or E3D Hotend mounting and at $15 it is a snip especially if you use there Robotdigg Alloy carriages (at $30 a set for open ended belts or $28 if you want the closed belt ones) carriages as well
Doug
September 18, 2015 09:18AM
Well the question was one of weight, and that video shows one with the extruder motor riding on the effector.
thereby negating any concerns one might have on effector weight.
the OP didn't say speed was important winking smiley
September 18, 2015 03:54PM
Well, the extruder stepper is connected through the flexible bowden and the rubber bands. It will always experience lower accelerations and therefore its weight should not be counted in full.
I would really like to see how can it cope with long quick moves and whether it would not catch some crazy oscillations (resonance) for some "unfortunate" gcode.
But yes, a slightly heavier platform will work too. The only consequence is a slightly smaller maximum accelerations.
September 18, 2015 04:39PM
Is it possible the metal effector could act as an extra heat sink for hotends?
Is it better for the hotend to be mounted above or below the effector plate?
Thanks everyone for your feedback so far.
September 18, 2015 07:09PM
Positioning a print cooling fan is easier with the hotend below the effector. I don't think this is much of a benefit though. The heat sink above the effector gives makes more vertical space available for the print. It also lessens the effects of a tilted effector (for example:if your arms aren't exactly the same length). The effector definitely increases the cooling area.
September 24, 2015 04:09PM
I just ordered a kossel effector in metal. 13bux shipped. Not a bad deal. I am hoping to use it as part of the heatsink and remove the fan altogether.
My Personal Blog. Build blog.
[engineerd3d.ddns.net]
Modicum V1 sold on e-bay user jaguarking11
September 24, 2015 04:39PM
jaguarking11
Don't know what hotend you are using, but with an E3D v6 I don't think the cooling will be sufficient, I think the heat will creep to far up the heatbreak to cause blockage.
The contact surface between the effector and the heatsink is at the highest point and rather small.
September 25, 2015 12:07AM
Even with the heat sink above the effector, I think you'll need the fan. The first fan I had failed during a print and the heat sink got quite hot.
October 26, 2015 03:14PM
To follow up with this. I got the metal effector in the mail. Its definitely way too heavy. Its also has a very small hole for the hot end. I am hoping to bore the effector out in the middle to atach the heat sink. I only print with abs, my retraction is less than 4mm, there is no problem in printing with no fan if the machine is not closed. Now that I have a heated chamber I installed a cheap very weak fan to the heatsink with no shrouding as I was getting the ocasional clog without it.
For me the plan is as follows.
1 - Bore out the center hole to almost the same size as the heatsink, This will reduce both weight and provide a contact point for the bottom fin to conduct heat to the body.
2 - Bore out lightening holes all around the metal plate to lighten it up as much as possible while retaining its strength.
The final goal is to get the metal plate to weigh in around the same amount as its plastic counterpart and remove the fan altogether, while reducing the hardware count (read weight) I will be installing spacers that are in the 10mm range, made of light antenna tubes to get the arm spacing proper.
All of this will not happen until at least December though.
Further thoughts.
Getting a cheap p4 era heatsink that is all aluminum and cut it into a triangle shape.
Cross drill the heatsink to reduce weight further.
Install spacers for arm mounting.
drill center hole in m6 format and install heatbreak. install bowden tube ontop.
Passive heatsink/effector combo with not too much weight. Being that most heat-sinks are extruded the quality would be superior to the cast parts I am seeing now.
