Kossel mini 170mm-200mm scale-up October 31, 2015 09:12PM |
Re: Kossel mini 170mm-200mm scale-up November 01, 2015 03:15AM |
Re: Kossel mini 170mm-200mm scale-up November 01, 2015 09:03PM |
Re: Kossel mini 170mm-200mm scale-up November 02, 2015 02:48AM |
Re: Kossel mini 170mm-200mm scale-up November 02, 2015 06:06PM |
Re: Kossel mini 170mm-200mm scale-up November 02, 2015 06:20PM |
Re: Kossel mini 170mm-200mm scale-up November 02, 2015 10:26PM |
o_lampe
It's still 120W at 24V. ( The resistance then is 4.8ish ohm )
At 12V you run two traces parallel, each has a resistance of 2.4 Ohm. Results in 1.2 Ohm.
At 24V you run the traces in series which results in 4.8 ohm.
-Olaf
