Scaling a Delta printer
Posted by lolocaledo
November 11, 2015 11:39PM
Hi all,
Once our printer is calibrated (M665 and M666), is it possible to adjust scaling it without modify calibration ?
in other words, my printer is very well calibrated (less than 0.05 after autolevel) but a piece of 5cm is printing 4.87
Re: Scaling a Delta printer
November 12, 2015 03:01AM
There are some M codes defined for X and Y scaling. I plan to implement these in RepRapFirmware soon. However, if your print is that far out then I suspect you have a bulld problem that is likely to cause distortion as well. Check that your rod bearing spacing is the same at both ends of each pair of rods.
November 12, 2015 03:46AM
A 6 point calibration doesn't include delta rod length. That's where the scale factor comes from. Reduce rod length and calibrate again.
-Olaf
