Different Magnetic Joint Style... Is it any good? November 20, 2015 12:28PM |
Re: Different Magnetic Joint Style... Is it any good? November 20, 2015 03:17PM |
Re: Different Magnetic Joint Style... Is it any good? November 20, 2015 05:01PM |
Re: Different Magnetic Joint Style... Is it any good? November 21, 2015 10:46AM |
Re: Different Magnetic Joint Style... Is it any good? November 21, 2015 12:34PM |
patrickrio
What holding force is necessary to keep everything together at high speed???? If I know the holding force necessary, I can select magnets and shaft diameter.
Also, since the Balls are 10mm spheres, what is the max cylinder diameter for 2 magnets on that ball without interfering with each other???
Re: Different Magnetic Joint Style... Is it any good? November 21, 2015 02:27PM |
Re: Different Magnetic Joint Style... Is it any good? November 21, 2015 09:33PM |
You can compute this. Let's say your steppers have holding torque 44 Ncm and you use 16 teeth T2.5 pulleys.Quote
patrickrio
Re: Different Magnetic Joint Style... Is it any good? November 21, 2015 09:52PM |
Re: Different Magnetic Joint Style... Is it any good? November 21, 2015 11:47PM |
patrickrio
I have found some 3/16 inch dia 1/2 long cylinder magnets that pull nearly 3 lbs/1.4kg each just connecting to steel (non magnetic) surfaces. 1/4 inch dia magnets can hold up to 7 lbs.
I just don't have an idea how much pull I need..... or how big I can go in diameter.
Paul Wanamaker
I had trouble when the nozzle bumped a curled edge, it would crash. I ended up using springs to increase the tension, and z hops.
I used high temp 3/8 x 3/8 cylindrical magnets rated between 8 and 9 lbs from here, as I have a heated chamber.
Re: Different Magnetic Joint Style... Is it any good? November 22, 2015 05:58AM |
Re: Different Magnetic Joint Style... Is it any good? November 22, 2015 07:06AM |
And the maximum accelerations and jerk used.Quote
etfrench
It will depend on how much your effector assembly weighs. Mine weighs 110 grams.Quote
patrickrio
Re: Different Magnetic Joint Style... Is it any good? November 22, 2015 09:51AM |
Re: Different Magnetic Joint Style... Is it any good? November 22, 2015 02:27PM |
Re: Different Magnetic Joint Style... Is it any good? November 22, 2015 02:39PM |
Re: Different Magnetic Joint Style... Is it any good? November 23, 2015 05:09PM |
Re: Different Magnetic Joint Style... Is it any good? November 25, 2015 04:22AM |
Re: Different Magnetic Joint Style... Is it any good? November 25, 2015 12:59PM |
Re: Different Magnetic Joint Style... Is it any good? November 25, 2015 01:05PM |
Re: Different Magnetic Joint Style... Is it any good? November 26, 2015 05:42AM |
etfrench
What is this flexible steel tube you speak of?
Re: Different Magnetic Joint Style... Is it any good? November 28, 2015 06:22AM |
Re: Different Magnetic Joint Style... Is it any good? November 28, 2015 03:23PM |
Re: Different Magnetic Joint Style... Is it any good? November 29, 2015 04:32AM |
Re: Different Magnetic Joint Style... Is it any good? November 29, 2015 08:56AM |
Re: Different Magnetic Joint Style... Is it any good? November 29, 2015 10:19AM |
