Hi all,
After making myself teeth on my first DELTA printer, I'd like to build a bigger printer, something like a 1,5m tower high, a 450 or 500 cm diameter area build with a E3D V6 hot end for 3mm filament and 1mm nozzle size. This printer will only print big object. However, is there any exist informations or documentations somewhere on the ratio between the high of tower and the lenght of the diagonal rods or between diagonal rods and build surface dimension ?
