My Large Kossel build: Feedback encouraged June 03, 2015 11:43AM |
Re: My Large Kossel build: Feedback encouraged June 03, 2015 11:58AM |
Re: My Large Kossel build: Feedback encouraged June 04, 2015 07:19AM |
dc42
- That 330mm diameter heater you link to is only 120W, which I am fairly sure will be nothing like enough power for that bed size to reach ABS printing temperatures.
Re: My Large Kossel build: Feedback encouraged June 04, 2015 09:00AM |
Re: My Large Kossel build: Feedback encouraged June 04, 2015 09:05AM |
Re: My Large Kossel build: Feedback encouraged June 04, 2015 09:11AM |
wayno complaino
Nice find! I see they don't have thermistors embedded like the other silicone ones i've seen and that could be a good thing from dc42's experience. Would sandwiching a thermistor between the silicone and the Ali be a more accurate solution? SRFR-12/10-P-230V would be the obvious choice here.
Re: My Large Kossel build: Feedback encouraged June 04, 2015 09:42AM |
wt
dc42
Was what you've used something like these? [www.omega.co.uk]
Re: My Large Kossel build: Feedback encouraged June 04, 2015 09:53AM |
Re: My Large Kossel build: Feedback encouraged June 05, 2015 04:31AM |
wayno complaino
All good info guys.
I discovered that my corners were slightly too big for my Mini Kossel to print so slightly amended, will print a test tonight just to see how it comes out. I'm keen to stick with the 2040 mainly as I've not seen one built in this orientation so it'll be an experiment others can learn from (even if its a "don't bother")
Re: My Large Kossel build: Feedback encouraged June 05, 2015 04:56AM |
wayno complaino
All good info guys.
Re: My Large Kossel build: Feedback encouraged June 05, 2015 08:45AM |
Re: My Large Kossel build: Feedback encouraged June 16, 2015 10:52AM |
Re: My Large Kossel build: Feedback encouraged June 16, 2015 11:19AM |
wayno complaino
Should be able to put an order in for the 2040 this week so i can try a printout to make sure the tolerances are good enough......
In the mean time here is the initial and simple plan for the top although there is no belt adjustment like the Mini Kossel, i think i will add that to the Carriage.
Re: My Large Kossel build: Feedback encouraged June 16, 2015 02:36PM |
Re: My Large Kossel build: Feedback encouraged June 16, 2015 03:43PM |
Re: My Large Kossel build: Feedback encouraged June 18, 2015 04:19AM |
Re: My Large Kossel build: Feedback encouraged June 18, 2015 06:25AM |
Re: My Large Kossel build: Feedback encouraged June 23, 2015 09:48AM |
Re: My Large Kossel build: Feedback encouraged June 23, 2015 04:15PM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 06:22AM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 06:38AM |
wayno complaino
V-slot is here and i've been trying to print some corners in ABS. Ether i need an enclosure or i stick to PLA for the frame parts.
Re: My Large Kossel build: Feedback encouraged June 26, 2015 06:50AM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 09:04AM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 09:17AM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 10:38AM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 02:24PM |
Freebird01
my build ended up going this direction... i used 8020.com 1020 extrusion for the head and base and the columns are makerslide. My corner connectors are printed but i chose to build my motor mounts and idler pulley mounts seperate and out of 16ga sheet metal.
Re: My Large Kossel build: Feedback encouraged June 26, 2015 02:39PM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 03:32PM |
Re: My Large Kossel build: Feedback encouraged June 26, 2015 06:10PM |
Re: My Large Kossel build: Feedback encouraged June 27, 2015 12:05PM |
