how to size bowden tubing? July 14, 2015 07:02PM |
Re: how to size bowden tubing? July 15, 2015 03:43AM |
Re: how to size bowden tubing? July 15, 2015 09:23AM |
Re: how to size bowden tubing? July 15, 2015 08:29PM |
Re: how to size bowden tubing? July 15, 2015 09:05PM |
Re: how to size bowden tubing? July 16, 2015 09:47AM |
Re: how to size bowden tubing? July 16, 2015 12:16PM |
dc42
I wouldn't use 3mm filament with a Bowden system. A Bowden tube for 1.75mm filament imparts quite a lof ot sideways force to the hot end, which used to cause the head angle to vary on my Ormerod printer. With 3mm filament, this force will be around 5 times higher, because I expect the sideways force to increase with the cube of the tube diameter.
Re: how to size bowden tubing? July 16, 2015 03:33PM |
wfcook
dc42
What causes a side force on the hotend in a bowden setup?
Re: how to size bowden tubing? July 16, 2015 04:09PM |
dc42
wfcook
dc42
The force needed to keep the Bowden tube bent instead of straight.
Re: how to size bowden tubing? July 17, 2015 11:05AM |
Re: how to size bowden tubing? July 17, 2015 01:26PM |
Re: how to size bowden tubing? July 20, 2015 11:29AM |
Re: how to size bowden tubing? January 07, 2016 09:29AM |
Re: how to size bowden tubing? January 07, 2016 01:17PM |
ImShogun
...That being said, I was thinking... What if a Z4 stepper would be added? Say from top of the delta, that stepper would arange for the extruder to always be around 20cm above the print head. meaning a short 25cm to 30cm ptfe tube could be used.
That could minimize both weight and torque impact on the print head.
Now, that needs implementation. I'm using Marlin.
Ideally, that Z4 stepper should always move the extruder at Z+200. that would probably be a good solution. We could also play with either math.avg(Z1,Z2,Z3) or math.max(Z1,Z2,Z3) but neither of these two adresses horizontal distance fluctuations between the hotend and the extruder so I'd keep Z+200.
Re: how to size bowden tubing? January 07, 2016 04:48PM |
Re: how to size bowden tubing? January 07, 2016 08:20PM |
