265mm 12V/24V round heatbed feedbacks needed February 17, 2016 04:59AM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 17, 2016 08:12AM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 17, 2016 01:19PM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 17, 2016 04:52PM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 17, 2016 09:04PM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 03:19AM |
WZ9V
I would not risk it on an Amazon SSR. The one I posted has a proper FET design with a low on resistance. There are a lot of cheap ones using a BJT that will get VERY HOT. I tested one that at 17A load was reaching close to 70C with the huge heatsink. Even with the heatsink and a fan it was still around 40C. The one I posted barely gets warm at similar loads.
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 05:49AM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 06:30AM |
darkoddio
please help, how to identify the voltage drop?
what about this SSR-60DD [www.amazon.it] ?
I'm a bit unwilling to buy from US, I would like to find an alternative in Europe
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 08:29AM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 01:10PM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 06:47PM |
darkoddio
Hi dc42
I somehow missed the Power Expander [reprap.me]
It seems that it is actually exactly what I'm searching for
Do you have any suggestion about the additional power supply?
Do you think the one I link here is enough? [www.ebay.it]
regards
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 07:31PM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 18, 2016 07:52PM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 05:45AM |
Anonymous User
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 07:11AM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 07:35AM |
Sir_Death
You can go the expensive way, of SSRs, 32bit electronic, ....
Anonymous User
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 08:04AM |
dc42
Sir_Death
I was suggesting using modern electronics (which may as well be 32-bit), NO SSR, and only one power supply. By the time you have spent money on a second PSU and SSR, you might as well have bought a decent controller board.
btw the IRF540Z is most definitely a bad choice for what you are proposing - it id designed for 10V gate drive, not 5V, as the datasheet [www.irf.com] makes clear.
The OP does have another alternative. Keep the main 12V power supply, use a separate 24V LED PSU (probably turned up to 28V) to feed the 11A input to the RAMPS, use the 24V connections on the bed heater, and drive it directly from the RAMPS. This assumes that the heated bed FET he replaced on the RAMPS is rated 30V or more. Also the 11A fuse on the RAMPS would have to be replaced by an automobile-type fuse to handle the higher voltage.
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 10:47AM |
dc42
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 01:45PM |
Sir_Death
dc42
Sir_Death
I do not see anything in the IRF540Z Datasheet for the need of 10V VGS...
Page 2: Static Drain-to-Source On-Resistance is max 26.5mOhm at 10V UGS - does not say what it is at 5V....
Page 2: Gate Threshold Voltage: Min 2V, Max 4V
Page 3: Fig 3. Typical Transfer Characteristics says even TJ at Roomtemperature, VGS at 5V -->ID of over 20A possible
Page 5: Fig 10. Normalized On-Resistance Vs. Temperature only gives the RDSon at 10V UGS... but it does not say 10V is needed...
I've built many electronic devices using IRF540Z always directly connected to 5V Controllers... they are still working - some of them since many years for 24h/365 days in PWM usage... --> always switching...
So "...most definitely a bad choce...." --> get some, test them and don't spread rumors if you never used them.
Sir_Death
EDIT: Maybe you should ad to your Signature why you would like everybody to purchase a 32bit Controller... and afterwards the paneldue....
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 01:56PM |
darkoddio
By "11A fuse" you mean I need to replace F2, like the one that RAMPS 1.4.2 has, correct?
darkoddio
But if I remember correctly the new MOSFET is irl2203n [www.irf.com]
If you mean Gate-to-Source, the value it is 16V.
darkoddio
BTW as far as I understood from other users experience, running the bed at 24V using 24V pads does not accelerate the heating process, while it is worth to run it at 14/15V using 12V pads.
darkoddio
What if I use a 14V power supply to feed the 11A input to the RAMPS? do you think I need to replace the F2 fuse?
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 06:08PM |
I was wrong, sorryQuote
dc42
I mean Vdss, which is 30V for that mosfet, so OK.Quote
darkoddio
mmm, I'm not an electrician expert, so maybe I'm wrong, but if the bed absorbs 120W and I use 14V 120W power supply, isn't the bed going to take 8.6A?Quote
dc42
Yes, because the bed heater will probably take more than 11A @ 14V.Quote
darkoddio
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 06:14PM |
darkoddio
Re: 265mm 12V/24V round heatbed feedbacks needed February 19, 2016 06:55PM |
Re: 265mm 12V/24V round heatbed feedbacks needed February 20, 2016 04:12AM |
Yes, thanksQuote
WZ9V
Power = Voltage * Current
Power = Current(squared) * Resistance
Current = Voltage / Resistance
As DC42 said power is not a constant, it depends on the Voltage and Resistance values. Since they control the Current and Current is the main driving factor in power as you can see I the two equations above the power changes as you change the voltage.
Re: 265mm 12V/24V round heatbed feedbacks needed February 20, 2016 05:09AM |
darkoddio
I also found a way to raise the voltage of my power supply up to 13.8 [www.ultimaterc.com]
Not sure if it is enough and btw I think I cannot connect it directly to 5A input on ramps
