Bed Calibration Issue February 16, 2016 05:43PM |
Re: Bed Calibration Issue February 16, 2016 05:55PM |
Re: Bed Calibration Issue February 16, 2016 06:16PM |
Re: Bed Calibration Issue February 17, 2016 03:30PM |
Re: Bed Calibration Issue February 17, 2016 04:20PM |
Re: Bed Calibration Issue February 17, 2016 05:27PM |
dc42
1. Varying trigger height on a delta is usually caused by effector tilt varying with XY position. Various things can cause this:
- Diagonal rods in a pair not being quite the same length (measured between bearing centres)
- Diagonal rod spacing (measured between bearing centres) not being quite the same at both ends of a parallel pair of rods. Fix this by adding shims under the bearings.
- Carriages not quite aligned with the effector (ideally, both the carriage bearing pairss and the effector bearing pairs should be at intervals of 120 degrees). If using wheeled carriages, fix this by adding washers or shims between the carriages and the wheels.
- Play in the joints, coupled with the sideways force exerted by the Bowden tube changing direction depending on its XY position. You can use springs to preload the joints, and elastic to support the weight of the Bowden tube form the top of the frame.
dc42
2. There are several things you can do to improve first layer adhesion:
- Correct heated bed temperature. If you have a glass bed then 60C is about right for PLA with most bed surfaces (you get about 5C temperature drop across the glass)
- Bed surface. Some PLA filaments can be printed directly on bare glass primed with vinegar. Other popular surfaces include Kapton tape, hairspray, masking tape, BuildTak, PrintBite, and PVA glue. I now use PEI which is one of the best, but this is still difficult and expensive to obtain in Europe.
- A low first layer speed
If you are getting actual bubbles in the extruded filament, then perhaps you have bad filament.
Re: Bed Calibration Issue February 17, 2016 06:38PM |
Re: Bed Calibration Issue February 17, 2016 09:20PM |
c3dprinting
dc42
I have added bands to my rods to achieve those settings, was worse before. I will try to check out the rods and work forward. Is there any problem for now with leaving the H values in there to correct it?
c3dprinting
dc42
I heat my bed to 65C for first layer, 60C for each after.
I have glass, was using Pritt Stick, tried elmers and a few others. Nothing quite perfect yet. Small prints do fine, just larger prints. I will have to look into PEI. Do you just you really thin tape to adhere it to your bed?
When I get it to work I run it at 50% normal. When it fails is at 100%.
Bubbles are not bubbles in the plastic but spaces between two lines where one line pealed up some and the next line came around and pushed it down somewhat. Makes for a ugly bottom if it does not fail.
Re: Bed Calibration Issue February 17, 2016 10:06PM |
Re: Bed Calibration Issue February 18, 2016 02:30AM |
Re: Bed Calibration Issue February 18, 2016 12:13PM |
c3dprinting
Just for fun (and extreme frustration) I took a piece of wood painted black and removed the glass and black paper. It calibrated first time out with a .05 margin of error. Powered off, moved the board, powered up and calibrated again. Once again same very small margin of error. No H figures no nothing.
So.... My guess is either the IR probe is having trouble with the paper, glass or both. What other kinds of things can I use / replace the glass / paper with? I have an aluminum heated bed below.
What do you use on the back of you PEI? Paint or?
Re: Bed Calibration Issue February 18, 2016 12:45PM |
Re: Bed Calibration Issue February 18, 2016 12:58PM |
Re: Bed Calibration Issue February 18, 2016 02:52PM |
c3dprinting
What paint did you use? I have found 2 choices: A high temp flat black (Rust Oleum High Heat Enamel Flat Black Spray Paint) and a high temp satin black ( Rust Oleum Bar-B-Que Black Satin High Heat Spray Paint). Will the satin black work OK, or should I go for the Flat Black?
I went with Opaque Natural for the PEI. Will that work OK or do I need to find a clear (have not found one yet)?
Re: Bed Calibration Issue February 20, 2016 03:05PM |
Re: Bed Calibration Issue February 21, 2016 12:49AM |
Re: Bed Calibration Issue February 21, 2016 03:04AM |
