Delta printing inverted (mirrored) X? March 06, 2016 11:39AM |
Re: Delta printing inverted (mirrored) X? March 06, 2016 12:26PM |
Re: Delta printing inverted (mirrored) X? March 06, 2016 12:31PM |
evandene
Hi ncshooter,
Allow me to throw in some stuff.
Are you using Machinekit (Linuxcnc)?
Your .ini setting are off somehow.
Do you have your end stops linked in series or separate connected to the specific controller pins?
If in series, the first end stop reached will win.
Re: Delta printing inverted (mirrored) X? March 06, 2016 03:42PM |
Re: Delta printing inverted (mirrored) X? March 06, 2016 09:22PM |
dc42
So tell us what electronics and firmware you are using, then some of may be able to help you with the homing issue.
The mirrored printing normally means you have assigned the XYZ towers incorrectly. Convention is that the X tower is front left, the Y tower is front right, and the Z tower is back centre.
