Does the modified Rostock firmware support manually moving the X / Y / Z axis with the LCD? I was trying to test the stepper portion before I assembled the rest and as soon as I go into the menu Prepare -> Move Axis then select any of X / Y / Z and press the select button all the motors start rotating, even before I tell it how far to move. They don't sound so good. Is this a firmware problem because there is no real X / Y / Z and the delta mods were made and the manual portion doesn't work? I get something like this while watching the serial output:
echo:enqueing "G1 F700 X0.1"
mm=0.10 seconds=0.01 steps=1
echo:enqueing "G90"
I have to reset the board to get it to stop moving all the steppers.
